LED rate blinking confusion
Page 1 of 1 [7 Posts]
animalman
PostPosted: Wed Nov 20, 2013 4:12 pm    Post subject: LED rate blinking confusion Reply with quote  Mark this post and the followings unread
Hey all, been lurking for quite a while after building some MFOS stuff.
First, big thanks for the deep well of information and charing inspiring work.
What has confused me a bit, is having a LED on the output of LFO/Osc.
You get a LED flash when the square is HIGH but never on the LOWs right? But I hear a tick (slow LFO) on both states of the cycle (high and low) but only LED indication on the high state of the cycle. So what I hear and what I see don't match up. Flashing at half the rate of the ticking SOUND.
Is this me doing something wrong. Or should I get me ears checked? Wink
Thanks in advance
-animalman
Former site admin
Audio files: 353
PostPosted: Wed Nov 20, 2013 4:33 pm    Post subject: Reply with quote  Mark this post and the followings unread
What you actually hear are the state changes ... low->high and high->low ... the LED makes those same changes on->off and off->on. Maybe looking at it this way will solve the confusion?
analog_backlash
Audio files: 21
PostPosted: Wed Nov 20, 2013 4:58 pm    Post subject: Reply with quote  Mark this post and the followings unread
You beat me to it Jan!
I'd add a welcome to animalman and say that being a square wave, the cone of your speaker moves in suddenly on the low-high transition and out suddenly on the high-low transition, producing two clicks. The LED only comes on during the high phase.
Hope that helps,
Gary
Former site admin
Audio files: 353
PostPosted: Wed Nov 20, 2013 5:33 pm    Post subject: Reply with quote  Mark this post and the followings unread
Hah, and you beat me to that Gary Laughing
welcome animalman
animalman
PostPosted: Thu Nov 21, 2013 10:42 am    Post subject: Reply with quote  Mark this post and the followings unread
thanks for the warm welcome! Very Happy
Wow you guys are quick to answer. And both of your replies really makes
perfect sense.
JingleJoe
PostPosted: Thu Dec 05, 2013 5:07 am    Post subject: Reply with quote  Mark this post and the followings unread
I also feel the desire to add that when the LFO is in the high or low state, there is nothing to hear because it's essentially DC (if we're talking about a square wave here). You hear the transitions because they have more high frequency harmonics than something which is, for all intents and purposes 0Hz.
analog_backlash
Audio files: 21
PostPosted: Thu Dec 05, 2013 8:08 am    Post subject: Reply with quote  Mark this post and the followings unread
Hi
That's perfectly true JingleJoe. In theory, it should be all of the odd harmonics. It reminds me of a (slightly sad) Fourier series program I did in QBASIC many, many years ago. If you add sine waves of frequency f, 3f, 5f etc together, you get a square(ish) result (see screen dump).
Gary
 Filesize:  13.2 KB
 Viewed:  420 Time(s)
