Linear detuning
rutgerv
PostPosted: Thu Aug 15, 2013 6:54 am    Post subject: Linear detuning Reply with quote  Mark this post and the followings unread
Here's an implementation of "linear" or "constant beat rate" detuning for the G2.
The normal/linear switch helps to hear the difference between normal and linear detuning. For note E4 detuning is identical in the two modes, but playing lower and higher notes illustrates how "linear" detuning maintains a constant beat rate over almost the entire range of keys (limited slightly by the precision of the notescaler module).
Best,
Rutger
lindetune.pch2
Linear detuning building block
 Filename:  lindetune.pch2
 Filesize:  1.97 KB
 Downloaded:  4253 Time(s)
