wheely
Posted: Wed Aug 14, 2013 2:49 pm Post subject:
High pitched frequency whine Subject description: DSI Tespest with G2 Modular |
| Plugged the DSI Tempest into G2 inputs (using it as an fx processor) and i can hear an annoying high freq whine. |
wheely
Posted: Fri Aug 16, 2013 3:24 pm Post subject:
| seems to be when i press EXT in ableton to allow external sync, weird. |
Audio files: 373
jamos
Joined: Jun 01, 2004 Posts: 517 Location: Eugene, Oregon, USA
G2 patch files: 44
Posted: Fri Aug 16, 2013 6:25 pm Post subject:
| If you're running Ableton on a laptop, try it without the power supply (batteries.) If that solves it, try a ground lift plug on the laptop power supply. |
wheely
Posted: Sat Aug 17, 2013 9:48 am Post subject:
there was some strange midi loop affecting it!!
unplugging the laptop made even more noise
thanks guys, its a bit better now, but i can still hear a faint whine. i think its the G2 power supply.
its been faulty since i bought it second hand on ebay last year.
once its on, if you turn it off, it wont power up properly again (make noise or connect to editor) always need to wait 5-15 mins almost like letting all the charge disserpate out before power on again.. weird, and a little annoying.
cheers tho guys. |
wheely
Posted: Wed Aug 21, 2013 10:59 am Post subject:
cant actually bare it anymore
gonna have to remove it from the chain, shame must be faulty.
are these normally silent? |
anigbrowl
Joined: Jan 21, 2008 Posts: 116 Location: San Francisco, USA
G2 patch files: 5
Posted: Tue Sep 24, 2013 12:45 am Post subject:
| Silent as the grave. Do you mean you actually hear a physical whine? I thought you meant through your speakers. but either way, should be silent when you're not playing. My G2 sits in a MIDI loop with my elektron gear. Ia m getting a Tempest within the next week actually, so I will try to reproduce your problem. |
tendril ferris
Posted: Sat Sep 19, 2015 3:03 pm Post subject:
I'm reviving this thread because I'm having the exact same symptom.
I hear a very high frequency noise in the audio as it comes into Ableton.
It's definitely originating in the G2 - does anyone else have this problem?
Are there other threads on the topic?
Is this a known issue for some people?
Is there anything I can do about it?
Pretty concerned, as it's one of those things that is a bit of a deal breaker - don't want this on my recordings. Granted, I can EQ it out for a lot of what I do w/ the unit, but I'm sure there are timbral patches I could make where I'd like to preserve that portion of the frequency spectrum.
Thanks for any advice...  _________________ t____
Former site admin
Audio files: 353
Posted: Sat Sep 19, 2015 3:08 pm Post subject:
| See what jamos posted above - its almost certainly a ground loop of sorts. |
Former site admin
Audio files: 353
Posted: Sat Sep 19, 2015 3:10 pm Post subject:
| And yes, there are some more threads about this, but better first check what happens when you disconnect the computer power (if possible) or pull the USB cable. |
tendril ferris
Posted: Sat Sep 19, 2015 5:22 pm Post subject:
Right on.
Well, it looks like I have a rare case, I suppose.
I tried pulling the USB cable and power connector for my laptop, no dice.
Did some tests, and realized that when I un-mute the G2's channel in the Fireface Totalmix software, there were phase cancellations happening in that particular channel (because of the summing from the Totalmix monitor channel and the monitoring in Live).
... more experiments with this and realized that *sometimes* the channel would *add* to the noise, but sometimes I'd get more of the cancellation thing.
I'd not remembered that I was plugged into one of the pre-amps via the front panel of the interface, and as soon as I plugged into the rear jack instead, the noise was gone!
Pretty stoked that it didn't turn out to be my unit in the end, but also kinda shitty about the fireface; hehe. I can live with it.  _________________ t____
Former site admin
Audio files: 353
Posted: Sat Sep 19, 2015 5:40 pm Post subject:
Heh .. that RME stuff can be tempting at times
Glad you found it tho. |
