DSP-cheap continuous tri-square-saw/ramp morphing oscillator
Tim Kleinert
G2 patch files: 236
PostPosted: Mon Jan 21, 2013 6:06 am    Post subject: DSP-cheap continuous tri-square-saw/ramp morphing oscillator Reply with quote  Mark this post and the followings unread
As the title says, a dirt cheap oscillator building block that allows continuous morphing between triangle, square and sawtooth/ramp waveforms. I discovered it by accident and thought it was rather neat. It uses less than half the amount of DSP compared a ShapeA oscillator.
Two parameters control the circuit: The bipolar SQR<>SAW control input provides continuous morphing between sawtooth, square (50/50 duty cycle) and ramp (negative sawtooth). The unipolar S/S<>TRI control input then provdes continuous morphing between this waveform and pure triangle.
t
SawSqrTriMorphTK.pch2
 Filename:  SawSqrTriMorphTK.pch2
 Filesize:  1.28 KB
 Downloaded:  4604 Time(s)
