cbright9
Joined: Apr 24, 2009 Posts: 2543 Location: Bristol UK
Audio files: 522
Wout Blommers
Audio files: 123
G2 patch files: 12
Posted: Sun Nov 04, 2012 9:13 am Post subject:
Uh...
You are asking what's going on here...?
(Synth has been reduced to fit the page...)
Anyway, the main operating part of the OS doesn't find the Keyboard any more, so it assumes it is a Rack. Probably you cut away something important...
Maybe someone from Clavia can tell you what to do. Sending some parts to install.
Wout |
cbright9
Posted: Sun Nov 04, 2012 11:30 am Post subject:
i didnt cut anything other than the metal that cases the synth and the extra plastic that the keys i removed were connected to. there are 2 PCBs that are responsible for the keys; one large PCB with the higher pitched set of keys that starts after the last key you see in the pic, and one PCB that starts with the lowest pitched key that continues to the last key you see. i simply unplugged the large PCB and cut the case down to size. it really is a cool modification. (i admit my metal working skills could use some work)
At any rate, im assuming that "rA" means its in rack mode? is there any way of toggling between the 2 modes? |
Wout Blommers
Audio files: 123
G2 patch files: 12
Posted: Sun Nov 04, 2012 3:30 pm Post subject:
No, the synth is doing it all by itself. When it detects the Wheel, PitchStick and Keyboard it 'knows' it is a Lead, otherwise it will be a Rack. Or the connection between Wheel and Stick is gone or it has to find the Keyboard.
I don't know exactly, but Clavia can tell...
Wout |
Audio files: 730
bubzy
Joined: Oct 27, 2010 Posts: 594 Location: United Kingdom
Audio files: 74
Posted: Tue Nov 06, 2012 10:23 am Post subject:
wow, cutting your synth in half.... thats a friggin GREAT idea.
please let me know the tools you used to do this, looks like a real neat job (im guessing you used a blowtorch and a spoon).
thanks _________________ _Richard_  |
cbright9
bubzy
Audio files: 74
Posted: Tue Nov 06, 2012 11:24 am Post subject:
i would be offended by your post but
a) im too dumb to understand it
b) the image you posted makes me laugh so much, i mean, whats the chances of someone else actually saying EXACTLY the same thing i did? genius _________________ _Richard_  Last edited by bubzy on Tue Nov 06, 2012 4:49 pm; edited 1 time in total |
cbright9
Posted: Tue Nov 06, 2012 11:28 am Post subject:
| "crickets" |
bubzy
Audio files: 74
audiodef
Audio files: 64
bubzy
Audio files: 74
Posted: Tue Nov 06, 2012 12:16 pm Post subject:
i think its a wicky sticket _________________ _Richard_  |
Wout Blommers
Audio files: 123
G2 patch files: 12
Posted: Tue Nov 06, 2012 12:52 pm Post subject:
Please, keep the discussion nice and friendly.
Wout
[forum moderator] |
audiodef
Audio files: 64
pablomastodon
Joined: Jul 07, 2010 Posts: 13 Location: Tampa, FL, USA
Posted: Wed Nov 07, 2012 6:41 pm Post subject:
NL1 Mod Subject description: keeping it friendly |
1) check wire connections from mod wheel and pitch stick to panel board
2) check C17 and C19 on panelboard. The config is NOT auto-driven. The keyed versions use 0.1uF caps in those positions; for the rack versions those are replaced with jumpers.
just my two cents, but someone who does a total hack job, literally, on this synth, after which the pitch stick and mod wheel no longer work, then joins forum as noob seeking free advice on how to undo the damage...well, that someone should be coming with a large degree of humility and some thick skin, because a certain level of mild teasing/abuse can be expected (and is probably deserved) |
audiodef
Audio files: 64
Joined: Dec 11, 2010 Posts: 1029 Location: Toronto, Ontario - Canada
Audio files: 83
Posted: Sat Aug 10, 2013 4:25 pm Post subject:
I just saw this thread now, and I LOVE IT! How did I miss this?
Anyway - I don't know if you ever fixed it, but if you could fit the PCB you removed into the shortened case and plug it back in then the synth would have no idea that the keys are actually missing.
It would be like one of those old housewife reality shows where the women still think that they are young and good looking, but their faces look like they have been molested by a wolverine and the skin from their necks stretched up above their eyes. _________________ JacobWatters.com |
adnauseam
Joined: Mar 27, 2013 Posts: 147 Location: Manitoba, Canada
Posted: Tue Aug 20, 2013 6:20 am Post subject:
Synth Chop Subject description: Comedy gold |
| Cynosure wrote: | | I just saw this thread now, and I LOVE IT! How did I miss this? |
Agreed. First thing I read today as I was poking through. Laughed quite hard almost sprayed coffee on my screen. (the wonka post)
I admit this is one ballzy move!
cbright: You may have some success finding another complete Nord Lead to observe the architecture of the stuff you cut away. There's likely some clues to point you in the correct direction.
-adnauseam |
