Analogic!
Page 1 of 1 [9 Posts]
JingleJoe
PostPosted: Mon May 07, 2012 1:57 pm    Post subject: Analogic!
Subject description: An old device recombobulated with a 4051 ANY gate
The video! It explains all, watch it with your eyes and listen to it with your ears.
The basic architecture of this device is this:
Code:
3 oscillators ---> {ANY gate} ----> resonant filter ----> out.
LFO ------------> {ANY gate}
I called it the Analogic Multiplex because its partially logic/digital but it has so much analogue stuff in there too! Wink
Draal
PostPosted: Mon May 07, 2012 4:05 pm    Post subject: Reply with quote  Mark this post and the followings unread
I like small units like this. They are cool on their own and can be part of a bigger orchestra of self contained units. Options, options Cool .
Zontar Prevails!
JingleJoe
PostPosted: Tue May 08, 2012 6:32 am    Post subject: Reply with quote  Mark this post and the followings unread
Yes indeed! I can imagine a rack full of devices like this bleeping in conjunction; either making a symphony or a cacophony Laughing
JingleJoe
PostPosted: Tue May 08, 2012 1:50 pm    Post subject: Reply with quote  Mark this post and the followings unread
While looking for the schematics for a different device I found the schematics for the analogic multiplex and by lucky coincidence the schematics for the other device were scrawled on the back! Very Happy
This circuit is the basis of the above device, however the above contraption also has a VCF and the LFO is light controlled too. The tri-PWM LFO control switch on the Y inputs was a bit ineffective because the triangle of the LFO is so small and biased up about two fifths of the supply, however it does make some noticeable change in sound but only just. I'd rather just use the PWM LFO and pull down resistors in place of the triangle output if I did this again.
You could amplify the triangle wave and remove the offset with a differential op amp amplifier though Wink
Overall circuit output is from the X output of the 4051, buffering it is advised but not allways necessary. All component values can vary alot, change oscillator capacitors to change overall frequency range.
LCO stands for Light Controlled Oscillator by the way Smile
 Filesize:  670.62 KB
 Viewed:  414 Time(s)
JingleJoe
PostPosted: Mon May 14, 2012 12:19 pm    Post subject: Reply with quote  Mark this post and the followings unread
This one is now for sale Very Happy Get it while it's still hot off the soldering iron!
Ye Threade of Ye olde Sale
Posted Image
aerogramma
Audio files: 15
PostPosted: Mon May 28, 2012 10:41 am    Post subject: Reply with quote  Mark this post and the followings unread
another great device?
how did you go about on the led controlled lfo?
cheers!
JingleJoe
PostPosted: Mon May 28, 2012 1:45 pm    Post subject: Reply with quote  Mark this post and the followings unread
cheers!
I think perhaps there was some sort of gramatical error there Laughing LEDs control nothing, the LFO controls the sound and the LED. LEDs are just an output transducer- turning electrons into photons.
aerogramma
Audio files: 15
PostPosted: Mon May 28, 2012 1:53 pm    Post subject: Reply with quote  Mark this post and the followings unread
ah yes sorry about that!.. I went ahead of myself, I'm thinking of an LDR controlled LFO, a pulsating led controlling lfo speed Smile
JingleJoe
PostPosted: Mon May 28, 2012 1:57 pm    Post subject: Reply with quote  Mark this post and the followings unread
You can get flashing LEDs though which could be used to make a really crude LFO with no frequency control, now thats what I'd call ramshackle Laughing
