Appendage Ribbon Controller Build Documentation
Post new topic   This topic is locked: you cannot edit posts or make replies. Moderators: jksuperstar, Scott Stites, Uncle Krunkus
Page 1 of 1 [3 Posts]
Audio files: 25
PostPosted: Tue Sep 20, 2011 7:34 am    Post subject:  Appendage Ribbon Controller Build Documentation
Subject description: a convenient place for all Appendage build documentation and build notices
Here is where you can get ALL the latest build documentation for your Appendage Ribbon Controller. It includes the latest build document and BOM. It is also a place where I will be posting any changes or modifications to the build documents. the latest of any drawings will, from now on, be kept here.
NOTE: THERE IS CHANGE TO ALL PCB REVISION "H" OWNERS THAT ADDS 4 PROTECTION DIODES. IF ANYONE HAS BEEN EXPERIENCING ANY U21, CD4053, FAILURES, THIS WILL FIX THAT PROBLEM. THIS MODIFICATION IS EXPLAINED BELOW IN THE NEXT POST
THE LATEST ROUND OF APPENDAGE PC BOARDS ON ORDER, REVISION "J" WILL ALREADY HAVE THESE DIODES INCORPORATED. THESE REV "J" BOARDS ARE SHIPPING TO ALL NEW CUSTOMERS. PLEASE NOTE THAT THE CURRENT BUILD DOCUMENT FOR REV H PCB'S CAN BE USED BUT THE NEW REV J BOM ADDS 4 BAT85 DIODES. SEE BELOW FOR DETAILS OF PLACEMENT
LINKS ------------- LINKS --------------- LINKS ---------------- LINKS -----------
THIS TOPIC HAS BEEN LOCKED SO PLEASE POST YOUR CONCERNS AND BUILD EXPERIENCES HERE:
http://electro-music.com/forum/topic-41078.html
VIDEOS OF THE APPENDAGE IN ACTION:
http://www.youtube.com/user/ScottStites
APPENDAGE ORIGINAL THREAD
http://electro-music.com/forum/topic-28138.html&postorder=asc&highlight=appendage
SOFTPOT SPECIFICATION DATA SHEET:
http://www.mouser.com/catalog/specsheets/SOFTPOTDATASHEETREV%20F2.pdf
BOM_1.07J.pdf
BILL OF MATERIALS FOR REV "J" PCB'S
 Filename:  BOM_1.07J.pdf
 Filesize:  51.93 KB
 Downloaded:  1978 Time(s)
Appendage_Exposed.pdf
Lean all about the Appendage Ribbon Controller. This excellent document is a MUST READ if your at all interested in this controller.
 Filename:  Appendage_Exposed.pdf
 Filesize:  398.71 KB
 Downloaded:  2126 Time(s)
Appendage_Build_Procedure_Issue_1_2_1_REV H PCB.pdf
BUILD & CALIBRATION DOCUMENT FOR REV "H" PCB'S
 Filename:  Appendage_Build_Procedure_Issue_1_2_1_REV H PCB.pdf
 Filesize:  12.18 MB
 Downloaded:  1934 Time(s)
PICKLIST_BOM_1.07J.doc
Parts Pick (Check) List for Rev. J PCB NOTE: Rev H Add (4) more BAT85 diodes D21-24
 Filename:  PICKLIST_BOM_1.07J.doc
 Filesize:  102 KB
 Downloaded:  1106 Time(s)
Appendage_Build_Procedure_Issue_1_3_REV J PCB.pdf
BUILD & CALIBRATION DOCUMENT FOR REV "J" PCB'S
 Filename:  Appendage_Build_Procedure_Issue_1_3_REV J PCB.pdf
 Filesize:  8.39 MB
 Downloaded:  996 Time(s)
Audio files: 25
PostPosted: Wed Sep 21, 2011 6:28 am    Post subject: Reply with quote  Mark this post and the followings unread
NOTE TO ALL PRESENT OWNERS OF APPENDAGE RIBBON CONTROLLERS WITH A REV H PC BOARD.
It has been brought to my attention and confirmed by Scott Stites that a potential condition exists that could cause failure of U21, CD4053 Analog Switch. Some dual power supplies where the -15V may come up some time before the +15 will cause a harmful negative voltage to appear at U21 analog inputs. To prevent this, four protection diodes can been added. The schematic attached shows the connections.
The diodes can be easily added to the solder side of the PC board under U19 and U20 operational amplifiers.
All new REV J PCB's will already have this change.
 Filesize:  89.54 KB
 Viewed:  1646 Time(s)
Audio files: 25
PostPosted: Wed Sep 21, 2011 6:50 am    Post subject: Reply with quote  Mark this post and the followings unread
PLACEMENT OF 4 NEW DIODES ON REV "J" PC BOARDS SHOWN BELOW.
Click on image to enlarge.
Thanks
Bill
 Filesize:  73.04 KB
 Viewed:  1529 Time(s)
 Filesize:  10.74 KB
 Viewed:  1354 Time(s)
