Who can help to make a stripboard layout? Buffered Multiple
Page 1 of 2 [35 Posts]
citric acid
PostPosted: Tue Aug 30, 2011 11:00 am    Post subject: Who can help to make a stripboard layout? Buffered Multiple Reply with quote  Mark this post and the followings unread
hello,
I ve tryed it now 3 times to do this on a hardwired breadboard but everytime i fail.
I can´t find the error.
can please do it someone on a stripboard ?
I think there are a lot of people who are happy when this is finished.
Thanks.
 Filesize:  33.09 KB
 Viewed:  52320 Time(s)
http://soundcloud.com/citric-acid-303
vladosh
Audio files: 55
PostPosted: Tue Aug 30, 2011 11:22 am    Post subject: Reply with quote  Mark this post and the followings unread
Here it is i think .. i missed those 1uF decoupling caps on the power strips ..
 Filename:  VOLT DISTR.bmp
 Filesize:  1.6 MB
 Downloaded:  1445 Time(s)
vladosh
Audio files: 55
PostPosted: Tue Aug 30, 2011 11:25 am    Post subject: Reply with quote  Mark this post and the followings unread
yes and mislabeled the 0.001 uF for 0.01 heh .. happens
citric acid
PostPosted: Wed Aug 31, 2011 7:52 am    Post subject: Reply with quote  Mark this post and the followings unread
thankls a lot men.
is there a chance that you show me where this cap´s have to be ?
Or can i let them out of this ?
ill try to build it after that i will give feedback , and if it´s ok for you i will share this to some friends.
thanks.
bubzy
Audio files: 74
PostPosted: Wed Aug 31, 2011 8:04 am    Post subject: Reply with quote  Mark this post and the followings unread
dont forget to cut the strip out in the middle of the IC Smile
citric acid
PostPosted: Wed Aug 31, 2011 11:14 am    Post subject: Reply with quote  Mark this post and the followings unread
do you mean this ? please see the edit
 Filesize:  75.91 KB
 Viewed:  980 Time(s)
citric acid
PostPosted: Wed Aug 31, 2011 11:20 am    Post subject: Reply with quote  Mark this post and the followings unread
and how do i have to solder the 1uF decoupling caps ?
vladosh
Audio files: 55
PostPosted: Wed Aug 31, 2011 11:57 am    Post subject: Reply with quote  Mark this post and the followings unread
in the layout there are already 100n ceramic capacitors that serve as decoupling caps .. but if you wanna add those 1uF electrolits you can use this .. for orientation .. there is a nice paper on capacitors i know it's on the fonitronic site i think it's called 101 capacitors http://www.modular.fonik.de/files/capacitors_101.pdf may wanna check it out ..
greetings
vlad
 Filename:  decoupling caps.bmp
 Filesize:  3.41 MB
 Downloaded:  1138 Time(s)
vladosh
Audio files: 55
PostPosted: Wed Aug 31, 2011 12:40 pm    Post subject: Reply with quote  Mark this post and the followings unread
here's a proper layout with the strips cut off in the back ..
cheers
about using it commercially if you think .. that's for MFOS to decide as for the layout you can use it as much as you want
 Filesize:  90.36 KB
 Viewed:  1169 Time(s)
 Filesize:  110.59 KB
 Viewed:  1035 Time(s)
citric acid
PostPosted: Thu Sep 01, 2011 11:51 am    Post subject: Reply with quote  Mark this post and the followings unread
thanks a lot men, nice work....no no idon´t wan´t to use it in a comercial way. i just wan´t to post it in our german forum at the diy section, there where some guys who also wan´t to have it.
its www.sequencer.de
thanks
citric acid
PostPosted: Thu Sep 01, 2011 11:54 am    Post subject: Reply with quote  Mark this post and the followings unread
the input is not there Smile but no prob i know where it must be Smile
vladosh
Audio files: 55
PostPosted: Thu Sep 01, 2011 3:19 pm    Post subject: Reply with quote  Mark this post and the followings unread
I've tried a few times to browse thru that page it's huge and i give up fast .. as i gave up learning german Smile
all best
vlad
citric acid
PostPosted: Thu Sep 29, 2011 10:43 am    Post subject: Reply with quote  Mark this post and the followings unread
your desighn was super...it works fine thanks alot men... so i saved another 60€ for buffered multiple....
so if i can help sometime please let me know!!!
Paradigm X
PostPosted: Sat Oct 01, 2011 4:45 am    Post subject: Reply with quote  Mark this post and the followings unread
Seems a good place to ask; whats the difference between a passive and a buffered multiple Embarassed
Thanks
Smile
vladosh
Audio files: 55
PostPosted: Sat Oct 01, 2011 4:53 am    Post subject: Reply with quote  Mark this post and the followings unread
I read someone comment once that when more than one vco is driven thru passive multi - there is a drop in voltage ..meaning out of tune , i don't care too much about such details for now as i'm using no tempco vco's anyway ,so i use a passive multi .. with buffered there should be no problems like that .
Paradigm X
PostPosted: Sat Oct 01, 2011 5:27 am    Post subject: Reply with quote  Mark this post and the followings unread
Ah, ok cheers Smile
citric acid
PostPosted: Sat Oct 01, 2011 5:45 am    Post subject: Reply with quote  Mark this post and the followings unread
also i use it for clock pulses. when you have a lot of mudules to run with a clock its some times hard to run them all tight. with a passive they sometimes run out of sync with this active multiple never Smile
vladosh
Audio files: 55
PostPosted: Sat Oct 01, 2011 2:14 pm    Post subject: Reply with quote  Mark this post and the followings unread
Makes sense using it that way .. i should make one too .
cheers
LektroiD
PostPosted: Mon Nov 14, 2011 12:00 am    Post subject: Reply with quote  Mark this post and the followings unread
What's the 20K resistor for? It doesn't seem to connect anywhere
Posted Image
citric acid
PostPosted: Mon Nov 14, 2011 9:05 am    Post subject: Reply with quote  Mark this post and the followings unread
its the input !!!
look at the first drawing Wink
emdot_ambient
PostPosted: Mon Nov 21, 2011 2:09 pm    Post subject: Reply with quote  Mark this post and the followings unread
vladosh wrote:
...i don't care too much about such details for now as i'm using no tempco vco's anyway ,so i use a passive multi .. .
That's a common misconception. Tempcos on VCOs are there to stop pitch drift due to temperature changes only. They have nothing to do with the tracking of the VCO.
Feed a constant CV to a non-tempco VCO, and set it in the sunlight. It will drift out of tune as the VCO heats up, even though the ptich CV hasn't changed. Do the same with a tempco protected VCO and the drift will be smaller.
But even the best temperature stablized VCO in the world will not play in tune if the incoming pitch CV has been split so much through non-buffered multis that its voltage has been degraded.
...of course if you're not making melodic/harmonic music, passive multis are totally fine. They're also usually fine for non-pitch related duties such as VCA or VCF Frequency modulation.
vladosh
Audio files: 55
PostPosted: Tue Nov 22, 2011 3:47 am    Post subject: Reply with quote  Mark this post and the followings unread
Thanks Emdot for clearing that out ..
greeting s
Vlad
rogerlatur
PostPosted: Sat Dec 22, 2012 4:49 am    Post subject: Reply with quote  Mark this post and the followings unread
I saw this thread seeking for buffered multiple tips and also found another schematic from Ray Wilson online. See attachment.
Wondered which one I should choose. The one attached or the one seen in this thread. More detailled here:
http://www.musicfromouterspace.com/analogsynth_new/OLDIESBUTGOODIES/VOLTAGEMIXER/voltagedist1.html
Cause the one attached looks more recent, has attenuator pots and has less components, caps etc. ("more simple" in a way, though the other one is not complicated).
Mostly I was wondering if I would have to change any component value for 15V supply use instead of 12V.
Also if this could be used without problem with audio signals as well... Not necessarily mixing AC and DC signals, but using this module for both uses.
 Filesize:  11.79 KB
 Viewed:  1294 Time(s)
PostPosted: Sat Dec 22, 2012 7:20 pm    Post subject: Reply with quote  Mark this post and the followings unread
I like the buffers from this project of Ray's:
http://www.musicfromouterspace.com/forums.html?MAINTAB=SYNTHDIY&PROJARG=CVANDGATEDIST/CVANDGATEDIST.html
I built a utility board that includes both the gate/trigger distribution and the CV distribution portions of that, one with and one without the voltage offsets.
Nardu
PostPosted: Sun Dec 23, 2012 8:47 am    Post subject: Reply with quote  Mark this post and the followings unread
Stripboards
 Filesize:  190.8 KB
 Viewed:  953 Time(s)
 Filesize:  98.24 KB
 Viewed:  983 Time(s)
 Filesize:  102.74 KB
 Viewed:  888 Time(s)
