VCO resistor question
Page 1 of 1 [3 Posts]
tbscope
PostPosted: Wed Jun 22, 2011 8:01 am    Post subject: VCO resistor question Reply with quote  Mark this post and the followings unread
Are the two 50k 1% resistors special resistors?
I'm looking on the digikey, farnell and conrad websites but can't find a normal 0.25W 1% 50K resistor.
I can find a 5W resistor though.
Before buying what I think are expensive resistors, I want to know if it is correct to assume that these are special resistors.
prgdeltablues
Audio files: 12
PostPosted: Wed Jun 22, 2011 8:14 am    Post subject: Reply with quote  Mark this post and the followings unread
If they are (and I can't myself decide), then you could always use two 100k 1% resistors in parallel instead.
Peter
yusynth
PostPosted: Wed Jun 22, 2011 1:38 pm    Post subject: Reply with quote  Mark this post and the followings unread
You may use 49.9K 1% resistors or 51K 1% resistors as well or as said above use two 100K in parallel
Yves
