syncing chuck to logic
Page 1 of 1 [2 Posts]
boba40
PostPosted: Tue May 24, 2011 5:08 pm    Post subject: syncing chuck to logic Reply with quote  Mark this post and the followings unread
Does anyone know if it is possible to sync mini audicle to logic pro
I want to write music in chuck and sync it to an imported movie in logic
I need to sync the time codes of logic and chuck
jordan
PostPosted: Fri May 27, 2011 8:53 pm    Post subject: Reply with quote  Mark this post and the followings unread
ChucK supports external data transfer through Midi and OSC. There's a few examples for that here: http://chuck.cs.princeton.edu/doc/examples/
for some reason, there's no example for doing Midi out from ChucK:
Code:
MidiOut mout;
MidiMsg msg;
// check if port is open
if (!mout.open(0))
   me.exit();
// fill the message with data
144 => msg.data1;
112 => msg.data2;   // note
while(true)
   127 => msg.data3;   // velocity
   mout.send(msg);
   125::ms => now;
   0 => msg.data3;
   mout.send(msg);
   125::ms => now;
As for the receiving end, I don't have a copy of Logic so I can't help you there, but someone else may have tried this specific setup before.
