egasimus
Posted: Fri Feb 11, 2011 5:54 pm Post subject:
Tips on S&H Lunetta? |
Hi all. Not sure if it classifies as a Lunetta, but I want to make a simple box which produces a sound similar to the intro to this:
I know it's digital, I think it's an ESQ-1, but can I get close to that sound in the (simple) analog domain? I guess I'd need an oscillator (what waveform does this sound like to you?), a filter (bandpass, if I'm not wrong), make those voltage controllable - and I'll need two simple LF398 S&H circuits for the CV. If I'm on the right track, then I'll be looking for the most simple and compact VCO and BPVCF - there's no need for accurate tracking in my case after all.
Thanks in advance for any help. I've been reading articles across the net, but I'm still quite new, and could use a few pointers. |
tjookum
Joined: May 25, 2010 Posts: 360 Location: Netherlands
Audio files: 26
Posted: Sat Feb 12, 2011 11:38 am Post subject:
welcome egasimus,
Cool sample and it will be a nice challenge to replecate that sound. But what kind of experience do you have? Saying you need a BPVCF is something else from actually building one. If you are totally new to this I would suggest to start with experimenting, it's very hard to make a specific sound.
That sound does resemble a squareish wave and that makes it lunetta territory. I have listen to it a couple of times now and I think it is some sort of fast square or pulsewave with a little reverb. To make the alternating tones you will probably need a simple sequencer, search the forum for the 4017 baby 10 sequencer. _________________ There he goes. One of God's own prototypes. A high-powered mutant of some kind never even considered for mass production. Too weird to live, and too rare to die.
Hunter S. Thompson
movies
noise |
egasimus
Posted: Mon Feb 14, 2011 12:13 am Post subject:
Thanks for the reply
Well, I can follow a schematic Never had the incentive to delve deeper and actually understand most stuff, but I learn quickly. Besides, I'm only 18 and intend to study electronics. I mostly build guitar effects for myself, and have some understanding in the digital domain, too, but have only recently started reading up on DIY synth building as something really worth my while.
I would like to build something like this, and maybe a drone box, to spice up the sound of my (new wave) band. I'm from Bulgaria, and it's kinda funny and sad at the same time that in the last 20 years, nobody has used that sort of sounds here - not in popular music, not in the underground. Avantgarde music here mostly died after the lead singer of Nova Generacia passed away. There's been a revival in recent years, but most bands here are happy playing the same unoriginal hard rock and heavy metal covers. Hell, I play bass for one, too
Anyway, about the synth. I replicated a vaguely similar sound in a VST called TAL-Elek7ro-II. What I did was set the two LFOs to S&H mode and route one to the VCO frequency and the other to the VCF in low pass mode, with the rates and intensities somewhat different, and the VCO resonance cranked up a little. I'd say 60% similar So your suggestion is that I made the alternating tones with a sequencer, instead of a S&H controlled VCO? Fair enough. Idea: two identical seqs running in parallel with slightly different clock rates. Opens up a lot of randomization possibilities: randomly alternating between both, or one seq resetting the other. Could do
What about the character of the sound, though? It's chaotic and at the same time tame. Am I on the right track about the bandpass? Last edited by egasimus on Tue Feb 15, 2011 10:06 am; edited 2 times in total |
Draal
Joined: May 18, 2010 Posts: 308 Location: Oak Park, IL
egasimus
Posted: Tue Feb 15, 2011 10:35 am Post subject:
Thanks, that's one thing I was looking for. Will try it out as soon as I can - I have an enormous backlog of stuff, too
By the way, there's more of that sound starting at 3:44. Does it sound kinda like ring mod to you? |
Draal
Posted: Tue Feb 15, 2011 11:30 am Post subject:
To my ears, it's ring mod with some other effect like a low pass filter. _________________ Zontar Prevails! |
