Inventor
Audio files: 270
Posted: Thu Feb 10, 2011 6:33 pm Post subject:
SL2OSC and ChucK Subject description: worked with pd but not ChucK |
Hi, I'm working with a friend on creating a bridge between the 3d VR world of Second Life and OSC, hoping to control ChucK with 3D objects and avatars. I got it working with pd, but ChucK seems to be blocking the port somehow. In fact, when I run pd and ChucK at the same time, pd fails but all I have to do is quit ChucK and pd magically works. I don't understand. Any suggestions?
Audio files: 373
Posted: Fri Feb 11, 2011 3:13 am Post subject:
I have a faint memory that UDP isn't in broadcast mode by default, so once a message finds a listener, it will go there and skip the others. UDP listeners don't hog a port like with TCP, so you can have several apps listening on the same port at the same time.
I think ChucK also has some problem with the data you are sending - is it possible to do a hex dump of a message that ChucK refuses to read?
Inventor
Audio files: 270
Posted: Fri Feb 11, 2011 3:47 am Post subject:
Stefan, these are the test programs. They work as localhost but not from SL. The event "e" just never fires, and I don't know why.
Les
 Download (listen) |
| Filename: |
OSCrecv.ck |
593 Bytes |
| Downloaded: |
341 Time(s) |
 Download (listen) |
| Filename: |
OSCsend.ck |
697 Bytes |
| Downloaded: |
352 Time(s) |
Inventor
Audio files: 270
Posted: Fri Feb 11, 2011 5:43 am Post subject:
OK we FINALLY, after much frustration, figured it out. Woody had implemented a subset of the OSC protocol for test purposes that only sent one value at a time. I was misunderstanding the identifiers but now I get it and it works. Thanks for the response, Stefan, even though you didn't have the answer it helped to have an extra pair of ears to talk it out with. (and brain between the ears lol).
Audio files: 373
Posted: Fri Feb 11, 2011 7:00 am Post subject:
Hehe talking to the monkey person often works. Could you tell us what the problem was? I had a quick look and couldn't see what was wrong..
Inventor
Audio files: 270
Posted: Fri Feb 11, 2011 7:50 am Post subject:
It was simply a case where we had created a temporary limited solution and not knowing much about ChucK with OSC, or OSC at all, I didn't know how to code the ChucK software properly for the temporary solution. But it works good now, and i've got a KS loop under SL control now. whoot!
