Audio files: 109
Posted: Sat Jan 01, 2011 7:39 am Post subject:
Mr. Cold!! ARGH, i was really hoping you'd have a recording, i was still in bed when you were on......
Here's the recording from the AcidTrash NYE stream...(thank you Howard!)
There's massive white noise in the first 2 minutes cuz i had the demo version of NiceCast running for over an hour.....but figured out what it was and reset.
Since this was our first show, we had a couple other problems too, but that's how you learn. We still had alot of fun trying to play for you guys.
Happy New Years!!
Joined: Jul 07, 2007 Posts: 2081 Location: Berks County, PA
Audio files: 90
Posted: Sat Jan 01, 2011 5:40 pm Post subject:
Subject description: Crater Dust and Passing
Thanks, Jan!
Here's the Acoustic Interloper set for this year, consisting of a Just Intonation rendition of Cohen's/Bowman's Crater Dust using a custom GUI with "player piano sequencer" live coding driving some Applied Acoustics physical models, and a spoken word Passing using some experimental reorg/granulation software that I am still working on, fed thru some effects in Live. Good call on the latter, Dr. Steve! The voice reorg stuff is still in a fairly primitive state due to lack of time, but I can see what needs to be done in the code after this coding frenzy up to NYE.
Happy New Year
DParsonNYE20102011CraterDustPassing.mp3
Crater Dust (Cohen & Bowman) and Passing (Parson)
Filesize:
26.45 MB
Duration:
28:54
Viewed:
3875 Time(s)
_________________ When the stream is deep
my wild little dog frolics,
when shallow, she drinks.
Audio files: 90
Posted: Sat Jan 01, 2011 5:59 pm Post subject:
Subject description: Just Intonation keyboard
Here is a screen shot of the alternate intonation keyboard that got its first run yesterday. The intonation is set by a scale-building function -- can be anything, not limited to Just or Equal -- and the keys that show up are a function of a small bit vector. Given the poor human interface nature of single click mousing, there is a 4 x 16 MIDI channel crossbar that helps support polyphony; each MIDI channel can do only monophony because the pitch bend for an alternate scale is specific to that channel's note. The high point, though, is the pop-up live coding window, one per MIDI channel, that lets one write sequencer code on the fly. Code for the keyboard is attached for Jython (Python-over-Java) fans.
screen shot
Filesize:
182.5 KB
Viewed:
1454 Time(s)
Joined: Jun 28, 2008 Posts: 575 Location: Marinha Grande, Portugal / Oslo, Norway
Audio files: 46
G2 patch files: 37
Posted: Sat Jan 01, 2011 6:33 pm Post subject:
shanemorris wrote:
paugui wrote:
Here goes my set
Will upgrade some info about it later
Paulo your set did not get uploaded here
True... it was taking a lot of time to attach the file and in the end no file was attached... :S
Not sure how much space it takes, but tomorrow I'll check that (it's a bit too late here now...)
It might take too much space too?
Or might slow internet not let it finish?
Cause I think it will likely take an hour or so to upload, as during the streaming I think it was uploading less than 128 Kb per second, and the Mp3 was encoded with 192 Kb per second...
Here's my set, with some edits due to a faulty cable, so if you hear some scratching in the left speaker do not adjust your set up, it is in the recording.
Might be indeed, I will give you more disk space. It does take quite some time to upload, but less than an hour I would expect ... it usually works, have faith
Here's the Tensor Sensellation set. I hope you enjoy listening to this as much as we enjoyed playing it. Thanks to all who organized, ran, and contributed to this event!
tensor_2010-12-31_EM_128.mp3
Tensor Sensellation Live set from the radio.electro-music.com New Year's Eve streaming event, Dec. 31, 2010 Copyright (c) 2010, (p) 2010 Tensor Sensellation
Filesize:
54.9 MB
Duration:
59:58
Viewed:
3951 Time(s)
Tensor Command Post
Filesize:
1.1 MB
Viewed:
1389 Time(s)
Audio files: 172
Posted: Sun Jan 02, 2011 6:09 am Post subject:
DES wrote:
Arrrrrrgh...
Max upload limit of 20 meg.... and I havn't loaded anything yet...
Can a moderator fix this so I can upload my NYE set?
bumped you up to 200mb and 50mb PM upload. _________________ Garret: It's so retro.
Parker: Like, old and outdated. Home,My Studio,and another view
