[SOLVED] Timing when reading data from OSC into array
Page 1 of 1 [3 Posts]
agkbill
PostPosted: Wed Dec 15, 2010 2:47 pm    Post subject:  [SOLVED] Timing when reading data from OSC into array Reply with quote  Mark this post and the followings unread
Hi!
Working on a sequencer app for monome (www.monome.org) but I can not get datainput from OSC to sync right in time.
As a start I work with one row on the monome, that is one row of 8 buttons with LED inside.
I use a array monome_row[] with 8 entry to store data about positions.
Active is LED on and 1, non active the opposing.
when the sequence is running the pattern moves one step every 250 ms for example.
I do that with a function move_monome_row[] that move all positions one step and put the last one first.
Then to show the state with the LED I have a function p_led that convert the positions in the array monome_row[] to a int that light up that pattern on the monome.
Well, all this work great.
The challenge is now to be able to modify the pattern in the array by pressing the buttons.
monome send three data, row, column, and state. State is if the button is pressed or not.
To initiate OSC from monome I use:
Code:
// create our OSC receiver
OscRecv recv;
// use port 8000
8000 => recv.port;
// start listening (launch thread)
recv.listen();
// create an address in the receiver, store in new variable
recv.event("/sleep/press", ",iii") @=> OscEvent oe;
For now I only use the x value.
Code:
while( true )
  200::ms => now;
   // get_ledd räknar ut värde för aktuell rad och skickar ut till monome genom p_led
   get_ledd( monome_row ) => p_led;
   move_monome_row( monome_row );
    // grab the next message from the queue.
    while ( oe.nextMsg() != 0 )
           oe.getInt() => x;
      oe.getInt() => y;
      oe.getInt() => state;
      x => xn;
      <<<xn>>>;
      <<<"monome_row" , monome_row[xn]>>>;
      <<<y>>>;
      <<<state>>>;
      if( monome_row[xn] == 1 )
        0 => monome_row[xn];
      else
        1 => monome_row[xn];
What I want is to invert the state of the position who button I press.
But I don’t get the response I want at all.
It is like the data I get pressing a button is not altering the array. If I hold it for a while it does but in a way that I cant control.
I should be able for example to follow a LED position moving and then by pressing the button in front of it for example adding that one.
Anyone who have any ide way I get this behavior?
All input most appreciated.
All the best!
/Christer[/code]
vrachnasormora
PostPosted: Wed Dec 15, 2010 5:32 pm    Post subject: Reply with quote  Mark this post and the followings unread
Hi Christer,
First you need to wait on the OSC event for incoming packets:
Code:
while ( true )
    oe => now;
        oe.getInt() => x;
        oe.getInt() => y;
if you use this loop as the main one, create a function that calls get_ledd and
move_monome_row every 200 ms and spork this one before the main loop:
Code:
fun void make_soup()
    while( true )
        200::ms => now;
spork~ make_soup();
while ( true )
    oe => now;
        oe.getInt() => x;
        oe.getInt() => y;
        x => xn;
        <<<xn>>>;
        <<<y>>>;
        <<<state>>>;
        else
I'm not sure but I also think that you may left the "Disable HTML in this post" checkbox empty before submitting your last post and the parser got naughty with your code.If you did, please remember to check it next time.
Don't let your code mess with mr. Parser.Bye Laughing
agkbill
PostPosted: Fri Dec 17, 2010 10:29 am    Post subject: Reply with quote  Mark this post and the followings unread
Dear vrachnasormora,
Thank you very much.
What happens there is that you kind of start another chuck program that are running in parallel and they are sharing data in the variables, int or arrays and so on.
Then it should be in that way I should do if I whant to use input from my PC-keyboard as well.
I did however had some work to get it working. When I tried the code the first time it did behaved very strange and not as I wanted at all.
I stripped down the function so I finally saw exacly what data that was handled.
Then I could se that my monome sent not one set of data but two!
first X, Y and state 1 (button pressed) but then when I released the button it send again X,Y and state 0 (button released).
That was the big reason for strange result.
I put in a line that make my arrange modification part only case about state 1 data and now it works very well!
Things is moving forward. Very Happy
All the best!
/Christer
