Small rack
Page 1 of 1 [2 Posts]
funkiness
PostPosted: Tue Jul 20, 2010 5:07 am    Post subject: Small rack Reply with quote  Mark this post and the followings unread
Hi guys,
I'm new here Smile
Do you know a small 8.75" rack ? I mean not a 19" normal rack.
A bit like the the doepfer small case but for bigger modules ?
Thanks !
Don Erskine
PostPosted: Sat Oct 16, 2010 2:11 pm    Post subject: Reply with quote  Mark this post and the followings unread
I presume you mean 8.75" (5U) high.
Several manufacturers (Dotcom, Encore, Modcan, Synthesis Tech, Oakley, Metasonix, to name a few) make modules this height, but other details of the panels vary - panel thickness, width (either multiples of 2.125", 4.5" or 1.75") and position of fixing screws.
Because of the various panel widths, it's unlikely a narrower cabinet would be available. For wider cabinets, take a look at the websites of the manufacturers above.
You may be able to cut a standard rack down to size, but it shouldn't be too difficult to make your own. Bear in mind that you may also want/need to find room for an internal PSU.
