Coming up on Radio 1 at
IC replacement Circuits ; TS200011, CEM3320 & SEM2044
Page 1 of 1 [5 Posts]
Hahnium
PostPosted: Mon May 10, 2010 3:01 am    Post subject: IC replacement Circuits ; TS200011, CEM3320 & SEM2044
Subject description: TS200011, CEM3320 & SEM2044 Replacement Circuits
Hi! I needed to fix up a couple of synths, and since these chips are heaps hard to come by, anyone know a replacement circuit.
I have the schematic for the KEIO TS 201012 used in the older Korgs, but I need those 3 to fix up some other older synth.
Can anyone help with these?
TekniK
PostPosted: Tue May 11, 2010 12:38 am    Post subject: Reply with quote  Mark this post and the followings unread
u are located in AU check here for ssm2044 ->
http://www.somaticcircuits.com/shop.htm
Hahnium
PostPosted: Fri May 14, 2010 12:39 am    Post subject: Reply with quote  Mark this post and the followings unread
Thankyou Very Happy
valis
Audio files: 6
PostPosted: Fri May 28, 2010 9:03 am    Post subject: Reply with quote  Mark this post and the followings unread
I could of swore that I had a schematic for the TS200011 around but all I can find right now is the TS200012. If you happen to find one could you post it or msg it to me? I'll let you know if I have any luck finding it before you do (I could of swore I had a copy somewhere...)
valis
Audio files: 6
PostPosted: Fri Sep 03, 2010 8:17 am    Post subject: Reply with quote  Mark this post and the followings unread
Here's the schematics for the TS200011 and TS200012. They should be easy enough to replicate on a breadboard. You may need to look into transistor substitutions though..
http://www.colinfraser.com/m700/
