Sound
Posted: Wed Mar 31, 2010 3:15 am Post subject:
Building The Appendage. Share your Experiences Subject description: A place to ask questions or just show off |
Hello I open this thread for share the building process of our appendages.
So ill start with a question...
I would like to add a switch in the front panel for length ribbon selection. I mean instead the internal jumper JMP1.
In order to use different ribbons.
Looking at the schematics -page D-2- I wonder if VR12 trimmer resistor should be adjusted depending on the ribbon length. I mean if a ribbon of for example 50cm will need same VR12 adjustment than other ribbon, say 100cm.
Anyone? Last edited by Sound on Wed Mar 31, 2010 6:20 am; edited 2 times in total |
Posted: Wed Mar 31, 2010 3:36 am Post subject:
The whole setup and calibration would need to be re-done for a different ribbon. AFAIK. _________________ What makes a space ours, is what we put there, and what we do there. |
Funky40
G2 patch files: 5
Posted: Wed Mar 31, 2010 3:58 am Post subject:
| Uncle Krunkus wrote: | | The whole setup and calibration would need to be re-done for a different ribbon. AFAIK. |
how much trimmers to set up ?
if not too much one could bring them to the frontpanel.
i also like to connect the appendige to ribbons from differenth lenght
( have not studied any docs yet ) |
Audio files: 25
Posted: Wed Mar 31, 2010 5:08 am Post subject:
Funky
Andy is correct. There would be several trimmers that would need to be adjusted to account for the different ribbon lengths and thus resistance. It would not be a matter of just bringing out the trimmers to a front panel but also several "test points" to measure voltages. Although the Appendage has a vast amount of strong attributes, this is one of it's weaknesses, the lack of having a ribbon "length" selection that would NOT require any recalibration. So, it's the 500 mm ribbon, or a smaller one, exclusively.
Hmmm, maybe version 2.0 will have an autocalibrate function.
Bill |
Audio files: 25
Posted: Wed Mar 31, 2010 5:13 am Post subject:
Hey Funky, I would like to make this topic Sticky and rename it:
SUBJECT: "APPENDAGE BUILDS, Share your Experiences" ....
SUBJECT DESCRIPTION: "A place to ask questions or just show off"
OK to do that?
Bill |
Sound
Posted: Wed Mar 31, 2010 5:59 am Post subject:
| State Machine wrote: | Hey Funky, I would like to make this topic Sticky and rename it:
OK to do that?
Bill |
Done. |
Sound
Thanks Uncle. |
Audio files: 25
Posted: Wed Mar 31, 2010 3:57 pm Post subject:
Awesome !
Thanks
Bill |
Danno Gee Ray
Joined: Sep 25, 2005 Posts: 1351 Location: Telford, PA USA
Posted: Wed Mar 31, 2010 4:11 pm Post subject:
| Nothing beats having a Sticky Appendage......thread. |
mark_olson
Joined: Oct 26, 2006 Posts: 177 Location: Lawrence, Kansas
Posted: Wed Mar 31, 2010 4:45 pm Post subject:
| Danno Gee Ray wrote: | a Sticky Appendage......
Agreed. But I think it isn't actually yet. We need to flag down one of the mods.
Mark |
Audio files: 25
Posted: Wed Mar 31, 2010 6:05 pm Post subject:
| Quote: | Agreed. But I think it isn't actually yet. We need to flag down one of the mods.
OK, I just made it stick ..... lol ... now we can truly say the Appendage is sticky !!
Bill |
Sound
Audio files: 25
Sound
Posted: Thu Apr 01, 2010 2:18 pm Post subject:
| Thanks Bill this helps a lot, Ill modify a little the design accordingly. |
oldmanfury
Posted: Sun Apr 04, 2010 5:36 pm Post subject:
my panel design |
Here's what I ended up doing. Pretty happy with the results, nothing was too cramped. I did end up grouping knobs / switches / I/O separately, which has its pros and cons.
-gerald
| I used FPD for layout - and hand drilled the panel myself, so the text and etchings are not in perfect locations. |
58.02 KB |
| Viewed: |
1563 Time(s) |
| Front Panel Express panel |
 Download (listen) |
| Filename: |
Appendage.fpd |
1.88 KB |
| Downloaded: |
1448 Time(s) |
Photon
Posted: Sun May 30, 2010 10:06 am Post subject:
| Perhaps this is common knowledge, but I noticed this morning that Jameco sells Softpots. The 500mm (item 2082708) is $21.95 and the 200mm (item 2082679) is $14.95. |
slo
Joined: Feb 18, 2007 Posts: 204 Location: Victoria, BC
Audio files: 25
Posted: Mon Jun 21, 2010 5:10 pm Post subject:
| Quote: | Appendage preliminary design, 17" panel to go in custom controller
Think I've got everything there, as you can see I did attempt to split it into the 3 sections. Made in Front Designer 3.0.
George |
Nice so far George The layout is very logical. I would like to make a suggestion. Since you had added multis to the TRIG and GATE signals, you might want to add some for all the CV outputs. You will definitely find that you will want to control more then one thing off a single output.
Nice work !
Bill |
slo
Posted: Mon Jun 21, 2010 5:21 pm Post subject:
| Quote: | | Since you had added multis to the TRIG and GATE signals, you might want to add some for all the CV outputs. |
Thanks for the input Bill, I'm a bit contricted in the design as I want to have all jacks at the top so as not to interfere with the ribbon below the panel, (cords sticking out) but I will think about it...........multis are good!
George |
Audio files: 25
Posted: Mon Jun 21, 2010 5:25 pm Post subject:
| Quote: | Thanks for the input Bill, I'm a bit contricted in the design as I want to have all jacks at the top so as not to interfere with the ribbon below the panel, (cords sticking out) but I will think about it...........multis are good!
Sure George, your welcome. Another approach is to just make a few "Y" cables and use those as your multis thus no panel space required.
Have fun with it ... it's looking great. I am loving the keyboard/ribbon controller rig your building.
Bill |
Audio files: 25
Posted: Mon Jun 21, 2010 5:27 pm Post subject:
| Quote: | | Perhaps this is common knowledge, but I noticed this morning that Jameco sells Softpots. The 500mm (item 2082708) is $21.95 and the 200mm (item 2082679) is $14.95. |
Dam Pete, your right. Just now looked at the Jameco catalog and there they are Thanks for giving everyone a heads up
Bill |
slo
Posted: Tue Jun 22, 2010 6:23 pm Post subject:
Any of you fine folks know where I can get a 3.5mm isolated TRS jack from, I've searched Mouser hi and low and come up with nothing. I would like to stay with that size for the Appendage ribbon connection.
George |
Danno Gee Ray
Posted: Wed Jun 23, 2010 3:49 pm Post subject:
Try Mouser PN. 161-3402-E
Kobicon 3.5mm Stereo |
Audio files: 25
Posted: Wed Jun 23, 2010 4:58 pm Post subject:
Hmm, be careful Dan. There is no indication on the data sheet that it is isolated. The ribbon TRS jack must be isolated. Just double check me on this guys
I did find this which may fit the bill quite nicely:
https://www.3dhdsupply.com/ProductDetails.Asp?ProductCode=30-711
Bill |
Danno Gee Ray
Posted: Wed Jun 23, 2010 6:57 pm Post subject:
| Roger that. The Kobicons do have a ground lug that is connected to the panel / frame. My bad. |
