rungsglas
Posted: Mon Jan 04, 2010 8:16 pm Post subject:
replacing small speaker with 1/4" line out |
| I am circuit-bending small kids toys and would like to replace the speaker with a 1/4" line out to plug into my recording equipment. Is it as simple as cutting the wires to the speaker and replacing them with the audio jack? |
rungsglas
electri-fire
Joined: Jul 26, 2006 Posts: 536 Location: Dordrecht NL
G2 patch files: 4
Posted: Tue Jan 05, 2010 10:39 am Post subject:
Hey rungsglas, don't be so harsh on our new member rungsglas! Little impulsive me has been guilty of being stunned by problems, asking things that could have easilly been answered with some Googling.
Well, ermm... welcome to electro-music.com. |
Former site admin
Audio files: 353
Posted: Tue Jan 05, 2010 11:03 am Post subject:
rungsglas |
electri-fire
G2 patch files: 4
Danno Gee Ray
Joined: Sep 25, 2005 Posts: 1351 Location: Telford, PA USA
Posted: Tue Jan 05, 2010 4:47 pm Post subject:
Welcome...to the club  |
imaguitargod
Posted: Tue Jan 05, 2010 9:54 pm Post subject:
Welcome dude! To answer your question harshly, I'll say, "Why haven't you just opened your third eye to the universe and downloaded the info directly from the ether yet? You fool!"
To answer your question in a welcoming manor I would say, "Yes, it is that easy........sometimes. Sometimes the voltage is not that nifty and you might have to throw a specific "voltage divider" inline. For more on that be sure to check out this link: http://fluxplayshop.blogspot.com/2008/07/voltage-dividers.html."
Hope this helps  _________________ Assistant brewer for Hoppin' Frog Brewery
My Noise Project: I Like Pie (MySpace Page) |
electri-fire
G2 patch files: 4
Posted: Wed Jan 06, 2010 9:23 am Post subject:
You nitwit!
Didn't you see this schematic: http://www.circuitbenders.co.uk/tips2.html IS a voltage divider?
This http://fluxplayshop.blogspot.com/2008/07/voltage-dividers.html uses higher value resistors, but as the ratio between them (10:1) is the same as in the circuitbenders schematic it outputs the same voltage, but has less current available (no problem, you don't need that).
The circuit expects an 8 ohm speaker, so the 10K-1K already reduces current a lot, the fluxplayshop scheme would be 10-fold easier still on battery drainage.
Both will work. Using a potmeter has the advantage of on board volume control , and to have the extra juice available when you WANT to drive the sound into distortion. |
imaguitargod
Posted: Wed Jan 06, 2010 2:41 pm Post subject:
| electri-fire wrote: | You nitwit!
It was a late night lastnight and I didn't check out his link  _________________ Assistant brewer for Hoppin' Frog Brewery
