Trouble sending/receiving NRPN messages between Cubase & A6
Page 1 of 1 [3 Posts]
Perfect Day
PostPosted: Mon Nov 16, 2009 11:30 am    Post subject: Trouble sending/receiving NRPN messages between Cubase & A6
Subject description: Trouble sending/receiving NRPN messages between Cubase & A6
Hi everyone ,I have my A6 set up with cubase 5 and an m audio midisport 2x2 . Im having trouble when i move the pots on the A6. The values are jumpy . The front panel is set to transmit and recieve Nrpn messages and local control is off . Whether I set it to transmit the data dense or thin makes little difference . although it does make some difference the knob movements are still imperfect . Does anyone here use the A6 with Cubase 5 ?I have also tried an emu 2x2 midi interface and I still have the same problem .Can anyone help me with this . also I have turned the sysex/ cc transmit recieve and program change paremetres off but it hasnt made any difference .Im using windows xp 32 service pack 3 at the moment not sure thats really important but just incase you needed to know . Thanks for your time
ThreeFingersOfLove
PostPosted: Mon Nov 23, 2009 4:21 am    Post subject: Reply with quote  Mark this post and the followings unread
Are the values jumpy when you turn the knobs or when MIDI is received?
Perfect Day
PostPosted: Mon Nov 23, 2009 10:33 am    Post subject: Reply with quote  Mark this post and the followings unread
Hi the values are jumpy when I turn the knobs . My prophet 08 also seems to be acting jumpy . Ive had 2 midi interfaces installed an old midisport 2x2 which requires a driver to operate and a Emu 2x2 that is class compliant . the problem seemed to start there . Ive since uninstalled the midisport driver and disconnected it but the problem remains . I normally get a sequence goin in Cubase loop it and then turn the knobs to get the sound . I have wireless and antivirus software turned off so they shouldnt interfere
