wave
Posted: Sat Sep 19, 2009 9:10 am Post subject:
Dave Smith Instruments - tetra 4 (new synth) Subject description: some questions / users here ? |
Hi forum,
I`m very interested in the new tetra-synth by DSI - I see the web-videos and read the pdf-manual ... I think the tetra is worth the price.
Question to tetra-users: I plan to use the synth without the editor (I`m not working with winXP) - is it possible to edit all kinds of parameter, especially the sequencer from the front panel ? Or there are some parameters I can`t use/change without the editor ?
Thanks for your help !
wave ... |
BobTheDog
dorremifasol
Joined: Sep 28, 2006 Posts: 823 Location: Barcelona, Spain
G2 patch files: 49
Posted: Wed Sep 30, 2009 9:57 am Post subject:
I owned the Mopho, and I suppose the Tetr4 is almost the same in editing.
You can edit all the parameters from the control surface, without exception, but it's not easy or comfortable. _________________ Cheers,
Albert |
wave
Posted: Thu Oct 01, 2009 3:59 am Post subject:
Meanwhile I`ve read the manual and it seems that it is possible to edit the whole unit without restrictions (incl. the sequencer).
Yes - this seems to be not very comfortable - unfortunately.
Maybe I`ll run XP on a second pc (only for the editor) - I have to think about that ...
Thanks for the tips & info. |
renegadebliss
Joined: Sep 08, 2005 Posts: 13 Location: Portland, OR
Posted: Tue Oct 13, 2009 9:23 am Post subject:
| wave wrote: | Meanwhile I`ve read the manual and it seems that it is possible to edit the whole unit without restrictions (incl. the sequencer).
What about using a midi controller instead? You can find a BCR2000 for $70 - $80 used, which is much cheaper then a second copy of Windows XP  |
wave
Posted: Tue Oct 20, 2009 2:31 pm Post subject:
"What about using a midi controller instead? You can find a BCR2000 for $70 - $80 used, which is much cheaper then a second copy of Windows XP"
Maybe a good idea - but I think this isnt comfortable and needs a lot of time to match all the parameters to midi-cc ...
I have already a second notebook (for my NM G1) - so I will update it to win xp and run the editor - I think thats the most comfortable way in my situation. |
