BobTheDog
Joined: Apr 24, 2009 Posts: 2543 Location: Bristol UK
Audio files: 522
Posted: Tue Jun 30, 2009 10:20 am Post subject:
Thank you kindly.
I will have a play with it and also replace the master oscillator with a live input to see how that works. _________________ Muied Lumens Sub Forum
Bandcamp |
driskel
Joined: Jun 04, 2009 Posts: 5 Location: Minneapolis, MN
Posted: Wed Jul 01, 2009 6:54 pm Post subject:
Thanks, being new to Kyma and this website I appreciate the tutorials.
How about now controlling the sound with an ADSR triggered by !KeyDown and the base oscillator's pitch via !KeyPitch? |
BobTheDog
Posted: Thu Jul 02, 2009 5:29 am Post subject:
Hi Driskel and to the forum.
I will knock something up and post here. |
BobTheDog
Posted: Thu Jul 02, 2009 8:20 am Post subject:
Actually I am beginning to think what I said above is incorrect
The Reset field of the oscillator is not acting how I thought it should.
I Am thinking about it.. |
driskel
Posted: Thu Jul 02, 2009 5:32 pm Post subject:
| BobTheDog wrote: | Actually I am beginning to think what I said above is incorrect
Not a problem, I appreciate the successes as well as failures. Regardless of whether you achieved your goal, I came across some interesting sounds due to your tutorial.
The miss-steps are as important as the steps.
Thank you. |
driskel
Posted: Thu Jul 02, 2009 5:37 pm Post subject:
Now in terms of the ADSR question. This is from memory. If I make a mistake I will correct.
1) Command/Apple b and search for product
2) Drag it onto the line exiting the oscillator on the right. Make sure that you do not drag it to the + symbol.
3) Command/Apple b and search for ADSR, and drag onto the oscillator that was created when added the product prototype
4) Click on the ADSR and if "!KeyDown" is not in the gate field add it.
4) If you are using a wacom tablet and want the gate to be triggered via PenDown use "!PenDown" instead of "!KeyDown" |
BobTheDog
Posted: Fri Jul 03, 2009 12:51 am Post subject:
Hi Guys,
The problem may be the reset field not running at audio rate, not quite sure yet.
I have asked on the SymbolicSound forum, you can follow this at http://www.symbolicsound.com/cgi-bin/forumdisplay.cgi?action=displayprivate&number=7&topic=000301
P.S. We are all beginners here!
Andy |
Audio files: 522
Posted: Fri Jul 03, 2009 8:27 am Post subject:
The control rate in Kyma is somewhere around 1 kHz IIRC, so if that is the only barrier it should work in some cases, but I have not yet had time to look deeper into this specific problem. Still going through the manual, learning the specifics of the timeline. _________________ Muied Lumens Sub Forum
Bandcamp |
