A6 serial numbers
Page 1 of 4 [89 Posts]
Goto page: 1, 2, 3, 4 Next
scd
PostPosted: Thu Jan 01, 2009 3:41 am    Post subject: A6 serial numbers
Subject description: Trying the find out the sequence :-)
Looking at two known serial numbers, I was wondering if people are willing to post theirs here, so we can determine what the numbers mean as far as possible?
(21)A10407045700043
(21)A10806045700936
The first one is from an older A6, the last one from a new batch, so I guess the first 04 and 08 describing production year, then it makes sense that the second 07 and 06 tell the production month and I guess the last three digits give the actual production number of the particular year (not necessairely meaning the numbers go up with 1 from number 1 on).
More serialnumbers will give a better insight. If you are not willing to post the number of your specific A6 in this thread, please send it to me privately and than I will post it here so no one know who'se A6 it is (except me Confused )
Something Completely Different
http://www.synthmusic.info
sunny pedaal
Audio files: 12
PostPosted: Thu Jan 01, 2009 7:49 am    Post subject: Reply with quote  Mark this post and the followings unread
first:
happy new year and best wishes !
and here is my serial:
(21) A6003020900021 sunny's!
( really don't understand any problem giving serials; even proofs this one is Mine, so lets everybody know that !) 003 might indeed be year: 9-2-2003 and number 00021
scd
PostPosted: Thu Jan 01, 2009 7:56 am    Post subject: Reply with quote  Mark this post and the followings unread
(21) A6 003020900021
(21) A1 0407045700043
(21) A1 0806045700936
(21) A6 003040300107
6003020300116
(21) A1 0607045700587
(21) 10607045700596
Are the ones sofar
seamonkey
PostPosted: Thu Jan 01, 2009 2:20 pm    Post subject: Reply with quote  Mark this post and the followings unread
scd has posted mine. I'm sure there's probably no harm in posting them, I just wasn't sure. Smile
Thanks scd for starting this thread.
seamonkey
PostPosted: Fri Jan 02, 2009 5:48 am    Post subject: Reply with quote  Mark this post and the followings unread
It does appear the lastcouple of digits could be the number madethat year. Confused
sunny pedaal
Audio files: 12
PostPosted: Fri Jan 02, 2009 6:53 am    Post subject: Reply with quote  Mark this post and the followings unread
lets give it a try/just a guess:
suppose serial1red +some blackversions
serial2 1-1000
serial3 2000-3000 ( with "A1")
would get something like this:
scd wrote:
(21)
A6 003020900021
6003020300116
(21) 10607045700596
more easily written :serialnumbers:
030209-00-021
030403-00-107
030203-00-116
040704-57-00043
060704-57-00587
060704-57-00596
080604-57-00936
it's just a guess, in fact i've no clue, is there anybody knowing more 'bout it?
and this meaning 2-3000 ( depending on numbers before 2003) made sofar ??
rokuez
PostPosted: Fri Jan 16, 2009 8:03 pm    Post subject: Reply with quote  Mark this post and the followings unread
from the back of my andromeda above the barcode but still on that same white sticker my s/n = (21) A10806045701012
Emulator Forum www.eiiiforum.com
sunny pedaal
Audio files: 12
PostPosted: Sat Jan 17, 2009 12:36 am    Post subject: Reply with quote  Mark this post and the followings unread
you have the newest from the serial list then?( just to check if my suggestion would fit
rokuez
PostPosted: Sat Jan 17, 2009 12:46 am    Post subject: Reply with quote  Mark this post and the followings unread
i suppose it is the most recent form the list. if you consider the last 5 digits are determining the production number
ThreeFingersOfLove
PostPosted: Sat Jan 17, 2009 1:59 pm    Post subject: Reply with quote  Mark this post and the followings unread
Mine is:
(21) A6003030900108
This one is actually my 2nd Andromeda. The first one was bought 6th Feb 2004, had a problem with one of the voices, sent it back and got another one in December 2004 (which still has a problem with one voice although less significant). I have written somewhere the SN of my first Andromeda but I don't remember where.
Maybe, there is a range of serial numbers with a naughty (or less naughty) voice.
wooperman
PostPosted: Thu Apr 16, 2009 10:21 am    Post subject: Reply with quote  Mark this post and the followings unread
I know it's a little late in the discussion...
(21) A10806045701000
wooperman
PostPosted: Thu Apr 16, 2009 10:52 am    Post subject: Reply with quote  Mark this post and the followings unread
Does it matter that the display reads "build 4-12-2002"? Or is that just the chip build date?
sunny pedaal
Audio files: 12
PostPosted: Thu Apr 16, 2009 4:07 pm    Post subject: Reply with quote  Mark this post and the followings unread
030209-00-021
030403-00-107
030203-00-116
040704-57-00043
060704-57-00587
060704-57-00596
080604-57-00936
080604-57-01000
it's the date of the software version?
SynthasaurusRex
PostPosted: Wed Jun 17, 2009 10:11 pm    Post subject: Reply with quote  Mark this post and the followings unread
(21)A10806045700988
But I won't have it long. It's got several problems, so I'll be sending it back. This is the second time they've sent me this one - with the same problems. Yeah, that's right.
- Stephen
SynthasaurusRex
PostPosted: Wed Jul 08, 2009 7:17 pm    Post subject: Reply with quote  Mark this post and the followings unread
(21) A10806045700909
And I won't be keeping this one either, unless I can get someone to promise they can repair it. Third shipment, second defective Andromeda, for those keeping score.
-Stephen
sunny pedaal
Audio files: 12
PostPosted: Thu Jul 09, 2009 12:09 am    Post subject: Reply with quote  Mark this post and the followings unread
what's the problem with it ?
SynthasaurusRex
PostPosted: Thu Jul 09, 2009 12:12 am    Post subject: Reply with quote  Mark this post and the followings unread
Hi Sunny,
Check this post: http://electro-music.com/forum/topic-35518.html
Thanks,
Stephen
Audio files: 282
PostPosted: Thu Jul 09, 2009 12:55 pm    Post subject: Reply with quote  Mark this post and the followings unread
(21)A6003020300025
The Real MC
PostPosted: Fri Jul 17, 2009 6:22 pm    Post subject: Reply with quote  Mark this post and the followings unread
That's the firmware, not the manufacture date.
Version "4-12" dated "2002"
Mine is #A60650009 beta unit #9 (I was one of the beta testers & sound designers)
sunny pedaal
Audio files: 12
PostPosted: Sun Jul 19, 2009 3:58 am    Post subject: Reply with quote  Mark this post and the followings unread
65-00-09 (beta unit nr 9) ?
030209-00-021
030203-00-025
030403-00-107
030203-00-116
040704-57-00043
060704-57-00587
060704-57-00596
080604-57-00936
080604-57-00909
080604-57-00988
080604-57-01000
SynthasaurusRex
PostPosted: Tue Aug 04, 2009 10:09 pm    Post subject: Reply with quote  Mark this post and the followings unread
(21)A10806045700999
I think I got a good one this time. cheers Third time's a charm.
Stephen
Numina
PostPosted: Sun Aug 09, 2009 8:21 pm    Post subject: Reply with quote  Mark this post and the followings unread
Mine is (21)A6003020800136
I bought mine used a year and a half ago. My unit works and sounds like a charm. Fortunately no major bugs. - J.
www.numinamusic.com
https://www.facebook.com/Numinamusic
marzzz
PostPosted: Sun Aug 16, 2009 5:49 pm    Post subject: Reply with quote  Mark this post and the followings unread
Mine is from the first production run in early 2001:
(21)A60500097
invalidbuffalo
PostPosted: Fri Aug 21, 2009 7:11 pm    Post subject: Reply with quote  Mark this post and the followings unread
Got mine on eBay a couple years ago for $1800 (what a deal!) No problems except for the half-assed packaging... The seller had UPS pack it and they just put the A6 in a box and poured peanuts over it without bagging or wrapping it in anything. It took me several hours to dig all the styrofoam out of the audio jacks and I had to open the unit to get peanuts out from inside it. The tempo control was also damaged in shipping. If you ever have to ship a synth, always, ALWAYS pack it yourself!
Anyways, mine is (21)A60500117 (also an early production one, probably in the same batch as marzzz's)
andyval8088
PostPosted: Thu Sep 10, 2009 9:35 am    Post subject: Reply with quote  Mark this post and the followings unread
This is what my Andromeda says (21) A10806045700921
Unfortunately I have to RMA the thing Sad
