seamonkey
Posted: Fri Dec 26, 2008 8:49 am Post subject:
Not using autotune |
I tried an experiment the other day when starting up my Andromeda, I let it warm up and never hit autotune just to see how badly it would be out of tune. Well, I was surprised to find out it was in tune, of course I have background tune and temp tune turned on as default but so far I haven't had to hit autotune.
Anyone tried this?
Btw I've had this for only 5 weeks and I love it more every time I play it.
It's one of the few synths I'ver ever purchased that the sound of over time doesn't grow tired on my ears, in other words I get sick of the sounds but the Andromeda is just as sweet as the first night I ran through the presets.  |
NordNerd
Posted: Sat Jan 03, 2009 4:44 am Post subject:
I've always let my A6 warm up,I rarely use the Autotune,infact I havent had to tune it for a few weeks now,but my Synths are left on for days on end.
I must be lucky that I got one of the decent batch of better Voice chips. |
soundwave106
Joined: Nov 24, 2004 Posts: 331 Location: Elmo's Mud Wrestling Club
Posted: Sat Jan 03, 2009 1:31 pm Post subject:
| I don't always have to tune up either. If the temperature in your studio is pretty constant, it's very possible to turn it on and play from the get go. (Even without background or temp tune.) |
Sir Ruff
Joined: Oct 10, 2006 Posts: 33 Location: Cincinnati, USA
Posted: Sun Jan 11, 2009 11:51 pm Post subject:
| My studio temp is constant-cold, but constant-and I definitely have to hit autotune, to start with, and then intermittently afterwards... |
kpatz
Posted: Sun Jan 18, 2009 7:36 pm Post subject:
| Most of the tuning drift seems to happen during the first 30-40 minutes after power on as it's warming up. With background tuning off, I can turn my Andy on, let it sit 30-40 minutes and then it's in tune without hitting autotune. Of course, if I'm impatient and start playing it sooner, it'll be out of tune unless I autotune, but then it'll drift back out as it finishes warming up. So I try to avoid using autotune until it's been on for a while (and then I may not need it, if I didn't autotune when cold), then it stays more stable afterward. |
lensfocus
Posted: Fri Mar 13, 2009 2:28 pm Post subject:
Background tuning is the same as auto tuning, it just happens in the background and takes longer to get to all the voices. So if you have background tuning on, it will sound the same as if you keep auto tuning it.
Jeff |
sunny pedaal
Joined: Nov 16, 2004 Posts: 735 Location: netherlands
Audio files: 12
Posted: Fri Mar 13, 2009 4:34 pm Post subject:
| not exactly as in background tuning it requires processorpower all the time, thereby slowing down your performance. noticeable in sliding when fast playing by example. i only keep temp-tuning on when playing and frequently only tune the oscillators when playinglive ( goes quicker and the filter seems less noicable) |
Joined: Feb 04, 2005 Posts: 2904 Location: Nottingham, UK
Audio files: 282
Posted: Fri Mar 13, 2009 6:20 pm Post subject:
I don't think I've ever needed to auto tune, I've found my A6 to be pretty stable tuning wise _________________ Jez
music | adventures in sound | gear for sale |
sunny pedaal
Audio files: 12
Posted: Sat Mar 14, 2009 2:01 am Post subject:
always autotune after 5 and 20 minutes, thereafter , mostly, only use osc-freq tune.
as default i leave backgroundtuning off, temptuning on |
soundwave106
Posted: Sat Mar 14, 2009 12:32 pm Post subject:
| lensfocus wrote: | | Background tuning is the same as auto tuning, it just happens in the background and takes longer to get to all the voices. So if you have background tuning on, it will sound the same as if you keep auto tuning it. |
Not in my experience. For a start, background tuning occasionally will not be powerful enough to cope with the drift (maybe if you let it sit a *really* long time things will correct itself I guess, but I'm impatient ).
For another, I find that leaving background tuning on noticeably changes the character of the sound. The sonic difference between temp tuning on and off is incredibly subtle; this is not the case for background tuning.
I'd love to hear the algorithms so I can have an idea of why this is so (I found a post on VintageSynth saying that temp tuning was simply a realtime formula calculation, but I am fuzzy on how background tuning works right now).
For now, I go with my experience: without background tuning the synth seems to "blend" with the band better, and have a more "lively" sound. It's nice to have background tuning, though, as it's an easy way to "correct" the Andromeda if it goes out of tune live. |
seamonkey
Posted: Sun Mar 15, 2009 7:26 am Post subject:
In my initial excitement I inadvertently commented I leave background tuning on, I leave it off and temp tuning on. I agree, having temp tuning on, any sonic difference to having it off is minimal to me.
I still like to let Andy warm up at least 15 minutes before playing tho.
Lots of great comments, thanks guys.  |
lensfocus
Posted: Mon Mar 16, 2009 10:58 am Post subject:
The tuning algorithms tune the oscillators by measuring the actual period of the output waveform of each oscillator at 9 different frequencies. Background tuning steals voices when they aren't being used, and tests each frequency until the voice is needed again. Because of this, the voice might be set to a very high frequency during background tuning. When a low note is played and needs that voice, the oscillator needs to quickly change it's frequency before the voice is heard. This takes some time, and especially if the range is large, you might hear the voice's oscillator moving to it's requested frequency as a chirp or slide. This is the main drawback to using background tuning.
The tuning algorithm is the same for auto tuning as for background tuning, which is the reason for my comment in my previous post. I agree that because of the above limitation, they do not act the same, and background tuning can cause unwanted artifacts. I tried to fix this a few different ways (it used to be worse..), and i think it's still possible but i didn't have time to perfect it.
Background tuning can take quite a bit longer than auto tuning depending on how active the voices are. And if just a few voices are being continuously played, the unused voices will be nicely in tune while the used voices won't get the chance to be tuned.
Background tuning doesn't, however, steal processing time while other voices are playing. The priority for processor bandwidth is always to the playing voices. This is partly why background tuning takes so long.
Temperature tuning is indeed a real-time formula calculation using the asic's internal temperature sensor. It compares the current temperature to the temperature that was recorded the last time the voice was tuned and provides a frequency offset to Vger. (We called the A6 sound engine Vger).
Jeff Platt
A6 software development |
sunny pedaal
Audio files: 12
Posted: Mon Mar 16, 2009 12:24 pm Post subject:
thank you so much for your kind explanation.
i was wonderring : would it have been , or be, very difficult to make a function whereby the voices "tuning table" could be set seperately for every voice and by the user itself , and that the autotune or oscfreq tune would use that values as default?
i ask that as it would maybe spare a lot of chipswitching due to a bad voice. and also make the tuning more strict or lose at will
and also i ask it as i still hope some time some further polishing of the software might happen.
anyway thanks again, highly appreciated |
lensfocus
Posted: Tue Mar 17, 2009 8:22 am Post subject:
| Sure, definitely possible. There are a few items I'd like to upgrade and or fix and or add to the mix. Alesis / Numark, however, has made it clear that they are not interested in hiring me again on this project, so there's not much I can do. |
Derek Daly
Posted: Wed Mar 18, 2009 4:02 am Post subject:
Thanks for this update, Lensfocus. I wonder whether Alesis would be interested in users contributing toward your hiring costs. I would be happy to donate $50 at least, and I'm sure others would throw in even more to see the long-awaited development. With say 100 people contributing as a very moderate estimate, you're already looking at $5000. So the company wouldn't have to pick up the tab - we, the users, would do that.
Incidentally, after reading through the numerous posts on this forum and at vintage synth, I managed to track down a brand new A6 at the end of last year. It arrived in Cape Town, South Africa in 2004 apparently and was part of a very small order from this music shop. It had been living in storage for five years. Everything is working beautifully, except for one button. Everyone who had a hand in bringing this synth to life, and indeed in spreading the good news about it, deserves our hearty praise. |
sunny pedaal
Audio files: 12
Posted: Wed Mar 18, 2009 7:48 am Post subject:
| 50 for me too, at least, although i understand it's a lot of work, many hours |
jonkull
Joined: Sep 22, 2006 Posts: 164 Location: Burbank, CA
Posted: Wed Mar 18, 2009 11:27 am Post subject:
| I'd like to see Alesis either support the damn thing or open source it. Sadly neither will ever happen. |
matia
Posted: Sat Mar 21, 2009 8:05 am Post subject:
i could also donate
but it seems hard to organize |
