espressogeek
Posted: Sun Nov 16, 2008 3:58 pm Post subject:
Which "format" for synth modules |
Hello,
I joined a few weeks ago and I am already putting together my first synth module, a TH-201. I also have a TH-101 PCB on order. As I assemble this and choose other modules it occurred to me I have no idea what to mount this in. What are the standard size front panels recommended for Thomas Henry designs and other modules such as the little-lfo and others?
Also, is there a general discussion DIY forum that would be more appropriate to post this in?
Thanks! |
andrewF
slo
Joined: Feb 18, 2007 Posts: 204 Location: Victoria, BC
espressogeek
Posted: Sun Nov 16, 2008 4:17 pm Post subject:
| Thanks andrewF! |
Sound
Posted: Mon Nov 24, 2008 8:11 am Post subject:
Hello slo, i like very much your mankato frontpanel.
espressogeek, I think that the decision of the format is the first that we must to do and usually one doesn't have enough experience for do it.
In my opinion you must to take this decision according the size of knobs that you will choose. This is very important because the knob is the one which you will communicate with the machine, as well the whole frontpanel.
With a little knob 11mm to 15mm. you will save space of the frontpanel, and will be OK 3 or 4U(eurorack and frack rack or Serge). You can achieve comfortable frontpanels.
With a big knob, >15mm you will have more precision, because you will have more knob travel. You will need 5U frontpanel. Also will be more easy to achieve a comfortable front panel.
I choosen the eurorack But if i could start again I would like choose 4U frontpanel, with 13mm knobs.
Think that 3U sometimes, with big PCB will be more difficult to place the PCB in the frontpanel. Ej, the finest Magsmoke PCB, in perpendicular mode, only fit in one way in the eurorack and you will need to much depth in the case. Or design dual modules, and place the PCB parallel to the front panel.
Keep in mind also the power supply and the case, If you go for eurorack you can solve it buying a doeper case with the power supply included, www.doepfer.de, But is 12V. or you can buy the subracks in ebay and make a external powers supply. Or you can make your own size.
http://www.modular.fonik.de/Page24.html
http://www.synthesizers.com/diycabinet.html
http://www.electro-music.com/forum/topic-22903-50.html
Hope that it helps and that my english will be understandable  |
