jukka_k
Posted: Thu Sep 25, 2008 3:43 am Post subject:
ChucK ensemble ? |
Anyone interested of starting a ChucK ensemble, not (necessarily) livecoding but collaborative compositions using exclusively ChucK ?
I've outlined a proposal for a program or 'rules' under discussion if (at least) few people are interested.
-Jukka |
cebec
G2 patch files: 31
Posted: Thu Sep 25, 2008 5:04 am Post subject:
| Absolutely great idea! I'm in... |
.dupion.
Posted: Thu Sep 25, 2008 6:42 am Post subject:
sounds good to me!
p.s. i probably should mention that i'm a complete beginner. maybe i could play the ChucK equivalent of the triangle or something?
p.p.s. don't feel obliged to accomodate me if its not in fitting with your idea  |
witt0191
Posted: Thu Sep 25, 2008 6:44 pm Post subject:
| me to sounds like a great idea |
jukka_k
Posted: Thu Sep 25, 2008 10:17 pm Post subject:
Great, at least a quartet ! Here is a program or 'rules' I've outlined,
let me know what you think:
| Code: |
Goal: writing ChucK programs together and independently
of others, collaborative compositions.
Rules:
1. Everything is done using exclusively by ChucK
2. Anyone can suggest a patch
3. Each participant makes one UGen of
the patch without being aware what others are doing.
No planning together !
(3. Max lines of source .ck is 40.)
(4. All music is monophonic, several sources can be run together.)
5. All finished sources are public-domain.
Items in parenthesis are optional, most important are 1. and 3., also 5.
Of course there are other options and variations for these, if you want to add/remove something and/or have other suggestions please do so.
-Jukka |
kijjaz
Joined: Sep 20, 2004 Posts: 765 Location: bangkok, thailand
Posted: Fri Sep 26, 2008 2:59 am Post subject:
This is a nice rule for building compositions and ideas for the band ^_^
From that, we can extend more into many areas.
I'm in also.
Let's make up some more rules to give example ideas for compositions. |
cebec
G2 patch files: 31
Posted: Fri Sep 26, 2008 4:57 am Post subject:
| Sounds good (the rules) but how would we start and then handle the collection of code? Would everyone write a small ChucK program on their own and then submit it at a specified time, etc.? |
jukka_k
Posted: Fri Sep 26, 2008 5:18 am Post subject:
Great kijjaz, yes let's start with these, we can add more rules when/if needed.
Here's a small template:
| Code: |
//ChucK ensemble template
Ugen1 => Ugen2 => Ugen3 => dac;
//UGen1: by xxx1
//UGen2: by xxx2
//UGen3: by xxx3
//dac: by xxx4
while(true) {
//dac: timing mechanism
Not too complicated, something where to start. I'm not sure of timing mechanism if it should be done by UGen1 writer (oscillator, impulse, noise generator, adc etc) or should it be done by dac-guy. I've tried to find a place to share the code, anyway basically I thought that each one will write his/her UGen and after we've all finished we build the whole program. If someone knows good online code editor or similar please let me know, I found few but not sure if they work properly. Here's one:
http://notebook.zoho.com
Sign up some username and we can share our code snippets. Other way would be just using email, both works for me.
-Jukka |
kijjaz
Posted: Fri Sep 26, 2008 5:39 am Post subject:
Ohh.. so the codes are gonna be played simultaneously?
It must be cool to incoporate codes by many chuckers into one chuck file.
but there should also be a system to sync / make the codes interact..
this would depend on each composition.
for example, we can set up a center system that each member's code can sync with / obtain information.
there can also be arrays that contain messages,
especially for interaction between each system.
some example ideas:
we might define a Metronome class that the codes can access.
so we can easily sync all the patches.
sequencer array:
make a universal int seq[][];
that each member can add members to it to form sequences.
so i can do like...
seq.size() => int MyMelody1;
seq << [0, 1, 1, 0]; // add my new melody
// .. etc ..
seq[MyMelody1] << 2 << 0 << 0; // add more members to that melody.
but this will need more planning. |
Posted: Fri Sep 26, 2008 6:10 am Post subject:
| Code: | public class clock
static Event @ bang;
static int pos;
static dur period;
static int pattern_length;
new Event @=> clock.bang;
.8::second => clock.period;
16 => clock.pattern_length;
while(1)
clock.bang.broadcast();
clock.period => now;
++clock.pos%pattern_length => clock.stp;
...and the same for scales, melodies, etc, etc, etc. Probably some public static Gain's as well to function as system-wide mixing busses.
If we can agree on what we need it's all quite possible. _________________ Kassen |
jukka_k
Posted: Fri Sep 26, 2008 6:26 am Post subject:
Yes, UGen codes simultanously and any source codes (complete programs)
too if we want. My original idea was to avoid synchronizing UGens ("manually") , that's why rule 4. (all music is monophonic), I thought that each UGen would be built independently to others, the whole would be a kind of non-deterministic automaton which would run using Chuck's timing mechanism and let Chuck automatically take care of synchronizing the files (if we use multiply source files). UGen's would be dependent of each others only if coder wants it but he/she must figure out how to do it. But of course this was just what I thought first, we can change and add rules/features as much we want.
-Jukka |
Posted: Fri Sep 26, 2008 6:44 am Post subject:
| jukka_k wrote: | | My original idea was to avoid synchronizing UGens ("manually") , that's why rule 4. (all music is monophonic), I thought that each UGen would be built independently to others, the whole would be a kind of non-deterministic automaton which would run using Chuck's timing mechanism and let Chuck automatically take care of synchronizing the files (if we use multiply source files). |
Are you sure you didn't mean to write "shred" where you wrote "UGen"? I suspect you made a typo there. A UGen is something like a SinOsc or Gain, you can't "manually sync" those; they are kept track of by the VM and ticked once every sample in a order dependant on the UGen graph (which is just a fancy word for "the way they are connected").
Typically people don't build UGens themselves as you need C/C++... that's beyond me right now though if Stephen would find the time to publish the tutorial he's been thinking about I'd be interested in giving it a go.
It's also quite possible to write a polyphonic section of music using just a single shred and a single UGen; LiSa has multiple voices in a single UGen.
I really suspect you are mistaken about a few of the words you are using or perhaps made a typo or two. Perhaps you could go over these last few posts and verify this is what you were meaning to say? Perhaps I'm misunderstand you completely? _________________ Kassen |
cebec
G2 patch files: 31
Posted: Fri Sep 26, 2008 7:01 am Post subject:
| Yes, I had the feeling you meant 'shred', too. |
Inventor
Audio files: 270
Posted: Fri Sep 26, 2008 8:11 am Post subject:
I'm in though I would like to have a more clearly defined code structure before going any further. I think that chaining UGens together as described in the original post was a good vague concept to get us started, but it won't work quite like that as Kassen points out. Let's set up something like the code snippet that Kassen wrote before we all go off and write incompatible code.
I could code one of my personal favorites, a Boolean Sequencer class. It might perhaps receive an event that says "one metronome note interval has passed" and then respond with an event that says "play a note" or "the frequency of the note is this".
Or I could call upon history and recode some favorites of the past, like Kijjaz's birds (I could give you the bird) or perhaps my motorcycle sound (bwaaaa whaaaa).
It might be good to have an enable/disable feature in the control section of the code so that something like a motorcycle only occurs at the beginning or end of the song, i.e. some master sequencing occurs rather than just chaos with no structure.
Also, what is this I keep seeing about "public class" whatever code? Is this new in the latest version of ChucK. I'm ashamed to say I didn't upgrade because I never use command line, only mini-audicle. Also, did mini-audicle ever get released with the new version of ChucK? If we're going to work together we need to all have the latest and greatest.
Great idea for building community! I'm in! _________________ "Let's make noise for peace." - Kijjaz |
cebec
G2 patch files: 31
Posted: Fri Sep 26, 2008 8:19 am Post subject:
| Inventor wrote: | | Also, did mini-audicle ever get released with the new version of ChucK? If we're going to work together we need to all have the latest and greatest. |
I contacted Spencer about this a couple of weeks ago, since I, too, use miniAudicle, primarily. He said he was busy, now, but he would do his best to get to releasing it as soon as he could with various bug fixes and the latest version of ChucK incorporated. |
jukka_k
Posted: Fri Sep 26, 2008 9:03 am Post subject:
OK, now I'm explaining this badly, I try this with (pseudo)code examples.
There's a game (at least here in Finland), you take a letter size paper or A4 in Europe, fold it to three parts. First player draws a head to first part of the paper and continues part of the neck to second part of the paper, next player draws a torso making lines to continue to third part and last player makes legs. As a result there's a human figure drawn by three people, usually funny (at least our kids liked the play). Same thing here, let's start patch like this:
| Code: |
SinOsc s => LPF filter => dac;
Needs three "players"/coders, first will done SinOsc, second low-pass filter and third will do dac (ie. timing with or without public class).
First coder makes a simple choice:
| Code: |
Std.rand2(60,88) => Std.mtof => s.freq;
If we do this in "chain" he/she announces that his part is finished and that he used freq parameter in his UGen. Player 2 makes his part, like:
| Code: |
if(s.last > 64) 200 => filter.freq;
else Std.rand2f(50,100) => filter.freq
or if he decides not to "synchronize" (bad choice of term from me) his UGen with first player then something like
| Code: |
Std.rand2f(100,200) => filter.freq;
Std.rand2f(0,2) => filter.Q;
Next he announces that he is finished and used freq parameter (and Q) and player three makes his/her choices of "synchronizing" his part, like
| Code: |
filter.Q()*400::ms => now;
in case he is "synchronizing", or
in case he is not.
The whole code would be something like:
| Code: |
while(true) {
//UGen1: by player 1
//UGen2: by player 2
//UGen3: by player 3
(Don't try this at home, at least I didn't ).
This is what I meant, what we are doing next, synchronizing timing by public class, running this with other program (or by itself) etc, is up to us,
all possibilities are open. Yes there are no way to sync UGen's (I didn't mean that, nor shred in this case), just poor choice of words from me.
Please let me know what you think, if this is stupid idea we can do something else or anything.
-Jukka |
Posted: Fri Sep 26, 2008 9:06 am Post subject:
| Inventor wrote: |
Also, what is this I keep seeing about "public class" whatever code? Is this new in the latest version of ChucK. |
No... I can't even find it in the "VERSIONS" file, must be from 2004 or earlier....
It defines a class that's accessible from anywhere in the VM. "static" means that variable will be the same for all instances of that class. This means that after running my example above you can use;
in any other shred and all of those will be synced up. Because you can also change the duration of a step by going
| Code: |
.4::second => clock.period; |
from anywhere in the VM all of those shreds will change their tempo so this is more powerful then
| Code: |
period - (now % period) => now; |
Notice that static non-primitive members need to be instantiated outside of the class or there will be trouble.
This is a essential technique for being able to communicate between shreds that come from different files (and so don't share name-space). The only other way to do that would be using OSC but that means loosing strong timing; network messages aren't realtime; there is no guarantee that they will be processed within a certain amount of time (actually there is no guarantee that they will arrive at all). ChucK's Event structure on the other hand *is* realtime, or at least as realtime as the underlying OS will allow a program to be.
| Quote: | I'm ashamed to say I didn't upgrade because I never use command line, only mini-audicle. Also, did mini-audicle ever get released with the new version of ChucK? If we're going to work together we need to all have the latest and greatest.
I know that for Linux ripping out the old ChucK from the Mini's source, inserting the latest ChucK source and compiling will work. This isn't harder then a normal compile. I didn't try that on Windows or OSX but my bet is that that will work as well. _________________ Kassen |
Posted: Fri Sep 26, 2008 9:11 am Post subject:
Jukka; got it! Thanks for clarifying.
One more note; "dac" is really quite limited in what you can do with it. Assuming you aren't allowed to re-/ dis- connect UGens then dac will only allow you to modulate it's .gain(). I suppose that may be interesting but all normal UGens allow that as well so... _________________ Kassen |
jukka_k
Posted: Fri Sep 26, 2008 9:20 am Post subject:
Great Kassen, this is just my poor explaining, especially when I'm enthusiastic, this doesn't happen first time in my life . Yes dac is limited, that's why he will get timing (and/or something else, it depends what we decide). We may re-/disconnect any UGen's, I can't see any reason why not.
Maybe starting from something simple is good first, things usually gets more complicated later.
-Jukka Last edited by jukka_k on Fri Sep 26, 2008 10:03 am; edited 1 time in total |
Posted: Fri Sep 26, 2008 9:34 am Post subject:
Cool, I like this game idea. _________________ Kassen |
Inventor
Audio files: 270
Posted: Fri Sep 26, 2008 9:57 am Post subject:
Here in the US, at least when I was in college, we'd write "cycle stories", great fun! First person gets small electric typewriter (tool of the 80's) and types in a few sentences as the beginning of the story, pass it around and each player types whatever they feel like. Gets really funny as the night and the drinking go on...
I'm in for cycle ChucK. I did think, however, based on the thread title that you meant we would make a song with each of us contributing an instrument or somesuch. I suppose in Cycle ChucK we would have to add lots of silly comments to make it funny as well. We could just post the code to this thread instead of emailing it, perhaps?
Kassen, thanks for the public / static tutorial. I don't quite get it yet but it will sink in with time. I get that you make a class and then the machine sets aside these static variables for it, then every instance of the class accesses the same shared variables, so it facilitates inter-shred communication. It just hasn't become intuitive yet and I'm one who is dazed and confused for a while until he gets it, then i'm good to go. So let it percolate.
Let's give Cycle ChucK a try! _________________ "Let's make noise for peace." - Kijjaz |
Posted: Fri Sep 26, 2008 10:18 am Post subject:
Les (re;Class),
Yes, that's basically right. Most of this (and a bit more) is covered in the manual as well, I think.
Note that when we are referring to a static member there is no need to instantiate the class as static members aren't unique to instances and instead belong to the class itself. This is why I didn't capitalise "clock" above. I didn't plan on ever having a shred go;
you can directly go to;
| Code: |
while(1)
clock.bang => now;
if ( !(clock.pos % 4) ) kickdrum.play(1);
//imagine "kickdrum" is something we already defined
Note that "clock" here *only* has static members.
If we want to keep all code in a single file for this then there is no need for such tricks but they do become important in multi-file constructs and they can be important if you want to update just a section of a structure while leaving the rest be, for example updating a instrument while keeping it's melody running so it'll pick up again once the updated code is executed. _________________ Kassen |
Inventor
Audio files: 270
cebec
G2 patch files: 31
Posted: Fri Sep 26, 2008 11:31 am Post subject:
| ok, how do we determine the order of the participants, though? 5 of us could be working on the same initial code simultaneously... |
jukka_k
Posted: Fri Sep 26, 2008 11:45 am Post subject:
How about this:
username: chuckensemble
password: chen88
There's Cycle #1 which I just wrote, mark your name to code,
I took Pan2, anyway don't show your code, who takes SinOsc,
just tell to JCRev when you're ready and tell too which parameters
you used, JCRev to Pan2 (me), me to dac-person, after we all are ready just fill your code and first is done.
Hope this works, let me know.
-Jukka |
