can cmos divide to musical 3rds, 4ths, 2nds,etc???
Page 2 of 2 [36 Posts]
Goto page: Previous 1, 2
loss1234
PostPosted: Sat Jun 21, 2008 7:13 am    Post subject: Reply with quote  Mark this post and the followings unread
blue hell: ok. that makes sense.
and then i could use the 4046 to multiply by a new division. or i could use another divider to divide again.
hey, isnt the 4089 a rate multiplier? or does that do something totally different? anyway, it seems there are lots of possibilities.
had anyone heard of that HUGHES chip i mentioned?
thanks.
loss1234
PostPosted: Sat Jun 21, 2008 7:16 am    Post subject: Reply with quote  Mark this post and the followings unread
jnuary
yeah now that blue hell pointed out the thing about having to connect the reset back to the division, i can see how you can get different divisions with the same clock. and i will have to study up on the OR gates.
i am trying to read the chapter in the cmos cookbook right now on how to use gates to get different divisions.
ALSO KRUNKUS-that excel table sounds awesome!!!
thanks all
jnuaury
Audio files: 9
PostPosted: Sat Jun 21, 2008 7:21 am    Post subject: Reply with quote  Mark this post and the followings unread
the OR gates i mentioned are just simple diodes not a decidicated cmos chip
i should really be careful about my choice of words....
Audio files: 353
PostPosted: Sat Jun 21, 2008 7:31 am    Post subject: Reply with quote  Mark this post and the followings unread
Yes it is, but this is a bit confusing as a rate multiplier is actually a divider Shocked Laughing
Apart from that it's pulses will not be evenly spaced so this will give rise to some odd harmonics. That being said, when going into a set of rate multipliers with a high frequency (above audio range likely) this will be interesting for generating fractional frequencies as well.
loss1234
PostPosted: Sat Jun 21, 2008 10:52 am    Post subject: Reply with quote  Mark this post and the followings unread
jnuary
no, i knew you meant diodes...but i need to learn how to do those as ors as well.
so, i TRIED the 4046/4017 combination, and then to be able to hear the frequency's a bit better, i put them through a 4040 to bring them down to a lower octave. i got some very nice musically useful stuff, espcially on the odd numbered interval outs.
this is a great new realm and i am not trying stuff with a guitar being squared, being fed to 2 4046's, one being multiplied through a 4024 and one through a 4017 and then both of those being fed to more dividers and mixed.
and then i want to use those outputs as control ins on things like the 4018 or data ins on shift registers, hook up a clock or two to drive the shift registers and mix that all together and, voila, filter it, and end up with something crazy!!
how does that sound?
Audio files: 353
PostPosted: Sat Jun 21, 2008 11:07 am    Post subject: Reply with quote  Mark this post and the followings unread
Don't know, I thought you were going to do the mp3s Shocked Wink
loss1234
PostPosted: Sat Jun 21, 2008 1:43 pm    Post subject: Reply with quote  Mark this post and the followings unread
well i dont have much room left for mp3s on this forum but MAYBE i could delete some old stuff
you got to hear this stuff
Audio files: 353
PostPosted: Sat Jun 21, 2008 1:47 pm    Post subject: Reply with quote  Mark this post and the followings unread
55 MB free I see, what are you up to Shocked
loss1234
PostPosted: Sat Jun 21, 2008 1:51 pm    Post subject: Reply with quote  Mark this post and the followings unread
hmmm
i guess i forgot someone gave me an increase
i will be posting soon
CJ Miller
PostPosted: Mon Jun 23, 2008 12:29 pm    Post subject: Reply with quote  Mark this post and the followings unread
Great topic! This stuff is amazing fun, and quite simple. It's surprising that synths and especially sequencers and drum machines don't make more use of these techniques. I wish I had some idea about this stuff when I started messing around with audio circuits, but I was scared away from CMOS until recently, for whatever reason.
It seems to me that the whole divider/multiplier confusion is caused by number of pulses vs duration. If I send a pulse into a circuit, and for every input pulse it sends out, say, five pulses - then it is multiplying the number of pulses while dividing time by 1/5.
loss1234
PostPosted: Mon Jun 23, 2008 5:49 pm    Post subject: Reply with quote  Mark this post and the followings unread
well i have been reading my copy of the cmos cookbook so much it has now fallen apart-literally. so i am now ordering another copy (and fredriksens Audio intuitive ic operational amplifiers)
anyway, i am also reading the TTL cookbook but i am not so good at translating the old chips into lunetta usable stuff.
anyway, i will post a sample soon
