larryreed
Posted: Tue May 27, 2008 3:18 pm Post subject:
ChucK takes long time to abort Subject description: After Ctrl-C (on WinXP), chuck seems to take up to 5 mins to 'clean up' |
I am a new ChucK user, developing stuff for realtime performance.
As I've been developing my code, I have needed to abort chuck fairly often in order to make changes. I have several questions:
First, why does it take so long for the VM to "clean up" and abort after I tell it to (with Ctrl-C)? Even if I kill the process with the task manager, it still seems to take several minutes.
Second, if I were to start a second VM while the first VM is still in "Cleanup" mode, what happens to new code added? Can I assume that the first VM is effectively gone, or is it still doing stuff with programs and resources (e.g. the midi device, etc.).
-- Larry |
Former site admin
Audio files: 353
Posted: Tue May 27, 2008 4:29 pm Post subject:
Larry
Did use ChucK really just a couple of times, but didn't see such slow aborts.
When I have programs (of my own) that won't shut down it usually is because one of the threads is still waiting for an event or a semaphore, this could be related to some device driver not behaving as expected. |
Posted: Tue May 27, 2008 6:12 pm Post subject:
Hey, Larry.
This is definitely not normal, quitting should take something like half a second or so, though it can take more if there's some issue that makes it crash. What version are you using? I've had some issues with the latest ASIO version (for this board) quitting in less then clean ways.
Unless you are defining public classes (which you can only clean from the VM by quitting it) there is no real need to quite the VM to update code. This may be a workaround until we diagnose the issue. _________________ Kassen |
larryreed
Posted: Wed May 28, 2008 2:59 pm Post subject:
Public classes - yes |
Yes, I am creating public classes. My goal is to create a set of public classes that can be accessed by various instantiated classes to manage my equipment. While I am getting these working, I find it necessary to quit the VM all the time. Since these classes need to refer to each other, I'm not sure how do it by updating private classes.
I am using v1.2.1.1, as downloaded during the last week.
Also, in the absence of include files, I need a way to provide a large number of standard definitions for various things like patch settings, etc, as it is really painful to have to use integer values for everything.
I'd be happiest with include files in which I could define constants private to whichever file includes them, but I'm ok with a set of public constants.
I'm coming from a C++ background, so I tend do things C++ style, although I do have Java experience as well.
Speaking of which, is there a way to specify that a particular item is a constant, so that it can't be changed?
-- Larry |
Posted: Wed May 28, 2008 4:17 pm Post subject:
Re: Public classes - yes |
| larryreed wrote: | | Yes, I am creating public classes. My goal is to create a set of public classes that can be accessed by various instantiated classes to manage my equipment. While I am getting these working, I find it necessary to quit the VM all the time. Since these classes need to refer to each other, I'm not sure how do it by updating private classes. |
Yes. Ok. In that case you will need to restart the VM a lot.
| Quote: | | I am using v1.2.1.1, as downloaded during the last week. |
I see. Clearly something is is wrong here and likely it's ChucK but Blue Hell may have a point that this might have to do with some issue addressing some hardware. Could you try the ASIO version? It's in one of the sticky topics in this section, near the top. It would be interesting to see if addressing the soundcard in ASIO mode changes anything, if so it's likely a matter of the interaction with the soundcard.
| Quote: | Also, in the absence of include files, I need a way to provide a large number of standard definitions for various things like patch settings, etc, as it is really painful to have to use integer values for everything.
-- Larry |
All of this makes perfect sense to me. I recommend emailing Ge;
ge at ccrma at stanford dot edu
With a detailed description of the "cleaning up" bug and your suggestions. Ge is always happy to look into bugs and suggestions though I do have to warn that lately he has been very bussy. _________________ Kassen |
larryreed
Posted: Wed May 28, 2008 4:39 pm Post subject:
Thanks! |
| Quote: | | I see. Clearly something is is wrong here and likely it's ChucK but Blue Hell may have a point that this might have to do with some issue addressing some hardware. Could you try the ASIO version? It's in one of the sticky topics in this section, near the top. It would be interesting to see if addressing the soundcard in ASIO mode changes anything, if so it's likely a matter of the interaction with the soundcard. |
I'm using a moderately old Gateway laptop (M205 if you must know, I hate it...but that's another story.] I have not been running to date with my sound card [no built in wireless , so I can't use my sound card and access the internet at the same time]. It's got a builtin Sigma Tel Audio, not sure if it supports ASIO. But I'll try it anyway.
I'll try getting in touch with [email addie removed by Blue Hell]. He's just down the street from me (well, 5 miles or so).
-- Larry |
Former site admin
Audio files: 353
Posted: Wed May 28, 2008 5:29 pm Post subject:
| Larry, I edited out the email addie that was a bit too obvious in your post, I know it's probably on the internet like everywhere, but still I think we should be a bit careful with 'm here. |
Posted: Thu May 29, 2008 4:31 am Post subject:
Re: Thanks! |
| larryreed wrote: |
Hmmmm. It would be a rare built-in card that supports ASIO but many can be made to work with it using this; http://www.asio4all.com/
However I wonder if it would still make a difference then. Did you try whether it may have newer drivers? Are you interfacing any other hardware? Hid? MIDI? _________________ Kassen |
larryreed
Posted: Thu May 29, 2008 10:32 am Post subject:
Using MidiSport 1x1 |
Well, I'm using a midi device, since my goal is to interface to my keyboard setup. Its a USB MidiSport 1x1. That device seems to work fine - seemed responsive enough to play as a thru device without any audible glitches.
-- Larry |
larryreed
Posted: Sat May 31, 2008 11:13 am Post subject:
Re: Program causing problem |
| larryreed wrote: | I've narrowed it down to the attached program. If I run chuck and then abort, or run some simple keyboard handling stuff, it quits right away. But after I run the attached program (gmidi.ck), it takes five minutes to quit.
First of all; I don't think any harm will come of it if you simply hard-quit ChucK from the taskmanager, waiting five minutes is silly.
Second; this is good because now we know that the MIDI is the problem... but it's kinda annoying that the device is a MIDI-sport because those work quite well so we can't blame it outright. Did you try updating/reinstalling the driver for it? Does it do such things with other programs as well? _________________ Kassen |
larryreed
Posted: Sat May 31, 2008 6:29 pm Post subject:
Midi shutdown issue |
Unfortunately, I have tried the task manager approach, and it still takes the 5 minutes. This sounds like it might be one more reason to hate my Gateway.
I haven't tried updating the drivers, so I'll see if that makes a difference. But I haven't had this type of issue with any other program, and I've been using the Midi Sport for several years.
Thank you for your help!
BTW, I noticed that there are a number of methods on the MidiIn/Out ugens that aren't documented (at least in the pdf doc that comes with the distribution). (e.g. Name()). Is there a more comprehensive list of such methods?
One challenge I have at the moment is that which device is assigned to my Midisport output changes depending on the configuration of the computer. For example, if I boot with the wireless card, and plug the midisport in after startup, the output port is device 2, but if I boot from scratch with my sound card (Creative Audigy 2 ZS) and the midisport both attached, the output port is device 1.
I don't want to have to keep modifying my chuck setup program each time I run the system, so I'd like a way of enumerating the devices and getting the info from them so I can determine the correct device automatically.
I'm not sure how to do this, other than check the name string. Can I (and if so, how) compare strings or something? Or is there some other device info I can check?
It would probably be helpful to be able to do similar things with the audio devices, to make sure my adc and dac gens go exactly where I want them to.
-- Larry |
Posted: Sat May 31, 2008 11:43 pm Post subject:
Here you go;
| Code: |
"hello" => string foo;
"hello" => string bar;
"hi" => string baz;
if (foo == baz) <<< "shouldn't happen" >>>;
if (foo==bar) <<< baz >>>; |
I'm really not so sure where to place the blame for the "5 minutes" issue but I too used a MIDIsport for years without issue though I think I borrowed it to a friend before I started with ChucK because now I have a soundcard that has 2x2 MIDI as well. The last thing I can think of is setting the "verbose" level as high as it'll go and hoping something useful shows up;
| Code: | ghost@baido:~$ chuck --verbose9 --loop
(ghost is me, baido is the name of this desktop, the $ is the Linux prompt)
A driver update couldn't hurt.
As for the devices ans strings; that's actually what I want to do for my own performance setup as well and I think it should simply work. The order in which the MIDI devices appear should be the order they have in the Windows settings with the "preferred device" on top of the list there getting id 0. For some reason Windows sometimes mucks this up so I too have been meaning to compare the strings to deal with that.
The functions that aren't in the manual should be, I'll make a not of it on the "manual erata" WiKi page. It's too sparse on MIDI info anyway. _________________ Kassen |
larryreed
Posted: Sun Jun 01, 2008 6:10 pm Post subject:
Verbose output |
Thanks for the --verbose9 tip, and the help on strings.
strings are not in the manual, which is why I got confused. At first, I thought there just wasn't any support for it, but then I realized there had to be if only to support the midi device name() method. So I tried constructing some string arrays, and voila!
Here is the verbose output after hitting ctrl-C. I run chuck --verbose9 --loop in one window, and chuck + gmidi.ck in the other. I get a bunch of output, so forgive me for including it all. The hang is while is is trying to shut down the real-time audio. Not a clue about this, I'm not doing any audio at all, and it doesn't matter whether I have my sound card installed or not.
Anyway, I've taken up too much of your time already. I found that by implementing stubs for my gmidi and midithru programs, I can develop a lot quicker, because so much of what I'm doing at the moment is the command infrastructure, and doesn't really need the midi stuff.
So I only have to deal with the timeout issue when I am testing the actual midi operations.
Thanks again!
-- Larry
| verbose output for 5-minute abort problem |
 Download (listen) |
| Filename: |
chuckout.txt |
6.54 KB |
| Downloaded: |
386 Time(s) |
Posted: Mon Jun 02, 2008 6:48 am Post subject:
Well, then... Then strings need to be on the list for inclusion in the manual as well :¬). New users of ChucK are a very valuable resource because they tend to find lots of stuff that's underdocumented that more experienced users glance over.
I'm happy to help, BTW, as long as I'm can address issues whenever I have a moment to spare it's all fun puzzles to me and considering how much ChucK has done for me it's only fair to do something back :¬)
That said; your issue here looks like it's beyond my skills to fix and you're going to need one of the Dev's. If it's really in the realtime audio that might actually point at a bug in the library that's used for that... or a issue with your soundcard... and that's beyond me, I fear.
At least we got a lot closer to pinpointing it. If you didn't already I suggest a mail to Ge and simply linking to this topic. _________________ Kassen |
