Haible Vokoder?
Page 1 of 20 [481 Posts]
Goto page: 1, 2, 3, ..., 18, 19, 20 Next
vtl5c3
PostPosted: Thu Apr 17, 2008 8:45 pm    Post subject: Haible Vokoder? Reply with quote  Mark this post and the followings unread
Hi Juergen,
I know that you've built a few vocoders over the years. Do you think you would ever design one for us?
Please? Pretty please?
(c;
Romeo
jhaible
PostPosted: Fri Apr 18, 2008 1:11 am    Post subject: Re: Haible Vokoder? Reply with quote  Mark this post and the followings unread
vtl5c3 wrote:
Hi Juergen,
(c;
Romeo
Maybe. Smile
My motivation to buy the Rimu PCB layout software originally was to build a vocoder, after all.
The big question - especially with a big, expensive PCB involved! - is, how big is the market for such a thing?
Well, I might distribute it over several PCBs.
My thoughts for a vocoder, if I ever make another one, go like this:
A reasonable number of bands.
Not too few - for good speech quality.
Not too many - I want the "analogue vocoder sound" - not something close to a digital solution. 14 ... 16 seem about right.
Lowest noise filters. I'd use the same technology as in the String Filter.
High dynamic range envelope detectors, with VC slew and freeze function.
A filtered (!) silence bridging like the Sennheiser. IMO, this makes all the difference in a lot of applications.
An interface for cross-patching and digital storage.
Cross ptaching: Everybody can choose his or her favorite means of cross-patching: a matrix, a patchbay, you name it. Or simply omit it.
Digital storage: Stora a "snapshot" of VCA settings. You can use the analogue freeze function for a coule of minutes, sure - but after that, you'd better store the parameters away in a RAM ...
JH.
Audio files: 19
PostPosted: Fri Apr 18, 2008 2:10 am    Post subject: Reply with quote  Mark this post and the followings unread
There was once a vocoder design idea in ETI that was entirely made from CMOS chips (for the filter bands)- making it incredibly cheap to build (like Jurgen quite rightly said- vocoders ain't cheap!)
ACHTUNG!
jhaible
PostPosted: Fri Apr 18, 2008 3:17 am    Post subject: Reply with quote  Mark this post and the followings unread
Without knowing that particular ETI design idea, I think it's save to say that it's never the active components that make a vocoder expensive. It's the passives: either tightly spec'ed or selected capacitors, or trimpots. And the front panel controls, the printed circuit board, enclosure, patch matrix - that kind of stuff.
JH.
Audio files: 19
PostPosted: Fri Apr 18, 2008 5:07 am    Post subject: Reply with quote  Mark this post and the followings unread
Oh yes I know Smile
The CMOS design hardly had any passives btw- what were there were just for tuning and levels if my memory serves me right- it was a long, long time ago! Wink Very Happy
ACHTUNG!
ringer
PostPosted: Sun Apr 20, 2008 10:18 am    Post subject: Reply with quote  Mark this post and the followings unread
I think a cross-pollination of the Sennheiser and the EMS 5000 would be a good starting point.
cheers
vtl5c3
PostPosted: Sun Apr 20, 2008 6:49 pm    Post subject: Reply with quote  Mark this post and the followings unread
Hi JH,
Sorry, I hope that didn't totally blindside you! Very Happy
I think 16 bands would be great. Crosspatching too. I think that creates a lot of possibilities. What does the 'Freeze' option do? Can you do choir type pads or something?
As far as market goes, I bet you'd get enough takers if you put the word out. I mean, did you ever think you'd sell as many frequency shifter boards as you did?
jhaible
PostPosted: Tue Apr 22, 2008 12:02 am    Post subject: Reply with quote  Mark this post and the followings unread
vtl5c3 wrote:
Hi JH,
Number of FS-1A boards came as a surprise, because I did my best to frighten as many of you away as possible, repeating all over what a difficult project it is, with capacitor measuring and resistor selecting, and the need of a scope and all. Smile
But then again, these two PCBs were rather cheap, cmpared to the price tag of a Moog/Bode Frequency shifter.
For a vocoder, it would be the other way round: Not that hard to build, but rather expensive, simply because it's so huge.
JH.
Audio files: 19
PostPosted: Tue Apr 22, 2008 4:05 am    Post subject: Reply with quote  Mark this post and the followings unread
JH, if you don't want a heart attack (!), I've got a number of old Elektor magazines, and I've also got the full Vocoder set too (I only think there were 2. 3 if you count the voiced/ unvoiced detector.
The PCB layouts are all there Smile
Shall I dig these out for anyone?
ACHTUNG!
jhaible
PostPosted: Tue Apr 22, 2008 10:12 am    Post subject: Reply with quote  Mark this post and the followings unread
It's been a while since I've seen these, but I definitely have them, or used to have them.
I don't rememeber the details, but it didn't seem that attractive at the time.
Especially when compared to the Elrad/ETI/Powertran vocoder which has been published around the same time. But I don't want to dismiss anything without being able to say why. Maybe if I see it again, I can tell more.
JH.
dar303
PostPosted: Tue May 13, 2008 1:45 am    Post subject: Reply with quote  Mark this post and the followings unread
Maybe you should do it entierly in SMD to keep the size down?
That would scare away a few but it's really not that hard to solder without any special tools if you keep the components at a reasonable size (0805 or 1206).
Peake
PostPosted: Tue May 13, 2008 8:32 am    Post subject: Reply with quote  Mark this post and the followings unread
An SMD vocoder would be a thing of beauty.
mono-poly
PostPosted: Tue May 13, 2008 8:38 am    Post subject: Reply with quote  Mark this post and the followings unread
You should base your desing on the EMS ones.
These are the greatest vocoders i know.
jhaible
PostPosted: Tue May 13, 2008 11:47 am    Post subject: Reply with quote  Mark this post and the followings unread
I'm not so sure about SMD.
Vertically mounted thru-hole resistors don't take more space than SMD resistors. Good quality capacitors don't come in SMD for large values - and small values means larger resistor values = more noise.
(Not speaking about electronics in general - just filter banks, vocoders, and stuff.)
JH.
jhaible
PostPosted: Tue May 13, 2008 11:55 am    Post subject: Reply with quote  Mark this post and the followings unread
I've reverse-enigineered the EMS 2000 / 3000 last year, starting with schematics without component values, and a lot of pictures from the inside of a 3000 - yes, translating (and often guessing) every single colour code. Smile
But I won't make any direct EMS copy for the same reason why I don't sell any VCS3 clone circuits etc.
But there is more.
I'm pretty convinced that Tim Orr didn't just make a scaled-down version for ETI after he designed the EMS vocoder (in part he did, most obviously), but that he also improoved some aspects of his earlier design.
And then there is Sennheiser, of course.
Plus, I have some additional ideas of my own. Smile
JH.
StephenGiles
PostPosted: Tue May 13, 2008 1:40 pm    Post subject: Reply with quote  Mark this post and the followings unread
Perhaps the only worthwhile circuits published by ETI were designed by Tim Orr. As ETI was legendary for it's minimal payments to designers, he must have had some clout with the rag through the advertising account!!
mono-poly
PostPosted: Tue May 13, 2008 2:36 pm    Post subject: Reply with quote  Mark this post and the followings unread
The Senheiser isn't that good imho.
jhaible
PostPosted: Tue May 13, 2008 3:22 pm    Post subject: Reply with quote  Mark this post and the followings unread
Hmm ... it's a tad noisy, and it doesn't have a slew / freeze function.
But its speech intelligibility and silence bridging blow the small EMS vocoders away. (Don't know about the 5000, though.)
It's fascinating how the Sennheiser makes a lingering sound suddenly start to "speak" without a noticeable crossfade - that's due to its multifilter, I think.
JH.
mono-poly
PostPosted: Tue May 13, 2008 4:33 pm    Post subject: Reply with quote  Mark this post and the followings unread
I think the ems 3000 vocoder is the coolest sounding.
To me it sounded cooler as the Senheiser somehow.
Even cooler as the Moog/Bode vocoder to.
But perhaps i just got a bad taste.
jhaible
PostPosted: Tue May 13, 2008 4:42 pm    Post subject: Reply with quote  Mark this post and the followings unread
I certainly love the EMS Vocoder on Oldfield's QE2 and Five Miles Out, and ABBA's "Me And I" !
And I think I hear a Sennheiser on Schulze's Audentity.
Smile
JH.
robovoice
PostPosted: Fri May 23, 2008 1:01 am    Post subject:  Vocoders
Subject description: Vocoder(s) used on...
Smile
JH.
Did "Five Miles Out" also use an EMS Vocoder? Because that's a Roland VP-330 Vocoder Plus MkI, the same as the "Prologue" intro to "Twilight" from the "Time" LP by ELO. On the "Out of the Blue" and "Discovery" LPs they used an EMS Vocoder 2000W MkI. Someone named "Micke" (not sure if he's here) says they used either of the Bode/Moog Vocoder's, but most likely the Bode because of the date (I remember watching a concert from Birmingham on PBS in which they used a Korg VC-10 Keyboard/Vocoder). Bode came-out a year or two before the Moog. Idk but I think 7702 stands for February 1977. Abba's last song with video was a vocoder song, drtn. The Sennheiser Vocoder VSM201 was used by Kraftwerk (they used most of "the golden age of analog hardware vocoders", but mostly the VSM201), Herbie Hancock, The Rockets, and Telex for example. Kraftwerk had two prototype vocoders that I know of, one built by Sennheiser (before the VSM201), and the other built by R. Barth KG (before the Musicoder). One of them was on eBay a year ago or so, but nsw.
I believe I hear the EMS Vocoder-System 3000 used in "Never Say Never Again". I also believe it to be among the EMS 1000, 2000, or 5000 (but not 3000 since it wasn't out then) and NOT the Sennheiser Vocoder VSM201 that was used as the voices for the Cylon Centurions from the original-series of "Battlestar Galactica"!! And Soundwave of "The Transformers" is one of the two Roland VP-330 Vocoder Plus models.
jhaible
PostPosted: Fri May 23, 2008 1:40 am    Post subject: Re: Vocoders
I'm not entirely sure about the the EMS on Five Miles Out.
But I think I remember the EMS 2000 from the "Live at Montreux 1981" DVD.
I guess I'll better double check this - so I have an excuse for watching this outstanding concert again. Smile
http://www.amazon.de/Mike-Oldfield-Live-Montreux-1981/dp/B000EU1KTG/ref=sr_1_3?ie=UTF8&s=dvd&qid=1211531324&sr=1-3
Also, EMS Rehberg does some advertizing with Oldfield:
http://www.emsrehberg.de/_______v_i_p___s/_______v_i_p___s.html
I saw that Barth vocoder on ebay. Would be interesting to see the schemos of this.
JH.
Now playing: Tori Amos, American Doll Posse
robovoice
PostPosted: Fri May 23, 2008 4:13 am    Post subject:  Re: Vocoders
JH.
So that was the Barth Kraftwerk Vocoder on eBay a year or so ago, not the Sennheiser Kraftwerk Vocoder? I wonder if that was legit or a scam.
jhaible
PostPosted: Fri May 23, 2008 5:39 am    Post subject: Re: Vocoders
I don't know - didn't know that only Kraftwerk had a Barth vocoder, either.
Actually, not exactly being the biggest Kraftwerk fan, I didn't know of any Barth vocoder until someone pointed me at that auction.
JH.
Now on the record player - guess what? - Oldfield, Five Miles Out. Smile
robovoice
PostPosted: Fri May 23, 2008 5:54 am    Post subject:  Re: Vocoders
JH.
Does he use both an EMS and the Roland VP-330 Vocoder Plus MkI, or just the VP-330+ MkI?
