Free: various home etched PCB's and usefull parts
Clack
PostPosted: Sun Feb 03, 2008 3:18 am    Post subject: Free: various home etched PCB's and usefull parts
Subject description: collectors only
trying to get rid of things i wont use - it would be nice if I could get something in return ( like a part? ), but I don't mind if you don't
Id prefer to just meet someone in London - preferably kings cross tube or somthing
top to bottom
Keyboard scavenged from broken organ - has a resistor bus to a common ground - I have 2 of them and this one was smashed came from a fairly good organ ( some Gem organ that seemed to have hundreds of features ) bottom B# and upward are fine - the ones below that are completely fucked. I am using the other one with rays keyboard circuit - works a treat
update: actually it has 3 Busses! just looked - so 3 switches per key! would be useful if you wanted to make some kind of 3 note polyphonic keybaord
Keyboard from some yamaha keyboard - fairly good quality though the keys are set up for matrix scanning - somthing weird like 8x11 wouldnt work straight of with ray's circuits - needs a lot of modification
Turntable i pulled out of some keyboard ( yes a keyboard! ) it was broken though, the motor is screwed - pretty useless really - er for some reason i have "black hole sun" by soundgarden in it um that comes with it.
Organ pedal, quite clunky uses a pot on a hinge havnt tested the pot but it is a regular one and probably can be replaced.
clockwise from top
Ray wilson (piezo)drum trigger
not available now sorry
YUSYNTH VC-LFO
http://yusynth.net/Modular/EN/LFO/index.html
(for some reason its underneath the other! this one was too big for my case )
Bergfotron dual VCHADSR
http://hem.bredband.net/bersyn/eg.htm
(note this one requires an extra board for the pots its not so simple)
Bugbrand pattern generator
http://electro-music.com/forum/viewtopic.php?highlight=pattern&t=18191
Clacktronics.co.uk
