aq
Posted: Mon Apr 23, 2007 9:50 am Post subject:
Nomad on MacBookPro not working |
Hi there
I am trying to get Nomad on my MacBookPro to work (without success so far). I copy the Nomad log below. It seems that there is a problem with Midi communication..
I have Mandolane installed which does work ok (Midi in/out according to the test app that is included).
Any idea how to get this to work?
Thanks.
B.
Nomad Version 0.2.1 (pre-release)
[os]
Mac OS X \ 10.4.9 \ i386
[java vm]
Java HotSpot(TM) Client VM \ "Apple Computer, Inc." \ 1.5.0_07-87
[java path]
java.library.path=.:/Library/Java/Extensions:/System/Library/Java/Extensions:/usr/lib/java
java.class.path=/Users/bernhard/Desktop/nomad/nomad.jar:/System/Library/Frameworks/JavaVM.framework/Versions/1.5.0/Classes/.compatibility/14compatibility.jar
property file:conf/application.xml
[STATUS] Loading splash:file:/Users/bernhard/Desktop/nomad/data/images/splash.jpg
[STATUS] Starting application.
[STATUS] [PROGRESS] Initializing
[STATUS] [PROGRESS] Images
[STATUS] [PROGRESS] Modules
[STATUS] [PROGRESS] Module builder
[STATUS] [PROGRESS] Themes
[STATUS] [PROGRESS] Nomad - 0.2.1 (pre-release)
[ERR]Communication timed out. [ERROR:524380898]
[ERR]net.sf.nmedit.jnmprotocol.MidiException: Communication timed out.
[ERR] at net.sf.nmedit.jnmprotocol.NmProtocol.heartbeat(NmProtocol.java:57)
[ERR] at net.sf.nmedit.jsynth.clavia.nordmodular.v3_03.NordModular$NmProcotolExtension.heartbeat(NordModular.java:265)
[ERR] at net.sf.nmedit.jsynth.clavia.nordmodular.v3_03.NordModular$MessageProcessor.processMessages(NordModular.java:346)
[ERR] at net.sf.nmedit.jsynth.util.SelfRegulatingThread.run(SelfRegulatingThread.java:85)
[ERR] at net.sf.nmedit.jsynth.clavia.nordmodular.v3_03.NordModular$MessageProcessor.run(NordModular.java:314)
[OUT]Closing midi connection.
[STATUS] Stopping application... |
aq
Posted: Mon Apr 23, 2007 9:52 am Post subject:
oh, I forgot to mention that I have a Micro Modular.
cheers
b. |
julien
aq
Posted: Mon Apr 23, 2007 12:52 pm Post subject:
yes, I did, but it doesn't make a difference...
cheers, b. |
chresan
Joined: Jul 11, 2006 Posts: 150 Location: Karlsruhe, Germany
Posted: Mon Apr 23, 2007 1:37 pm Post subject:
Hi aq,
which midi device are using ? Has the midi dialog multiple entries with the same name ?
Christian _________________ ----------------------
http://nmedit.sf.net |
pixelmechanic
Joined: Jan 04, 2008 Posts: 3 Location: edinburgh, uk
Posted: Thu Jan 10, 2008 5:20 am Post subject:
Hi All
I'm happy to report that I can get Nomad to work with MacBook Pro and Micro Modular...
Mandolane didn't work for me... but this does...
http://www.humatic.de/htools/mmj.htm
Jules |
julien
Posted: Thu Jan 10, 2008 6:18 am Post subject:
Hello pixelmechanic,
That is great news. Can you post your configuration: Java version, macos version, midi interface. This info may prove useful in the future.
I suppose that you tried the latest release not the CVS version ?
Julien |
pixelmechanic
Posted: Thu Jan 10, 2008 6:31 am Post subject:
Hi Julien
Here's the info you requested...
Mac OS: 10.4.11
Java version: 1.4.2_16
Midi Interface: M-Audio Midisport 4x4
Nomad Version:0.2.1 (Current)
I've also got a small question... would I need to compile the cvs version or can that be downloaded as a jar also?
Jules |
julien
Posted: Thu Jan 10, 2008 6:58 am Post subject:
Thank you for the info.
Unfortunately, there is no available distribution for the CVS version. So you have to compile it yourself. If you want to do so contact me I'll forward the instructions, they not yet on the developer website. Another point on the todo list...
The next release is very close anyway. |
pixelmechanic
Posted: Thu Jan 10, 2008 7:00 am Post subject:
OK, I'll wait for the release
J |
mandolane
Posted: Wed Feb 27, 2008 10:45 am Post subject:
Hi pixelmechanic
What problems did you get when you tried using Mandolane? If possible, we'd like to address these issues.
Mandolane |
