RtAudio Samplerate
Page 1 of 1 [4 Posts]
everamzah
PostPosted: Wed Apr 11, 2007 11:52 pm    Post subject: RtAudio Samplerate Reply with quote  Mark this post and the followings unread
can someone tell me how to change the samplerate for RtAudio? i'm using chuck on linux with jack. i run jack at 44100, and RtAudio wants to run at 44800.
tia
PostPosted: Thu Apr 12, 2007 6:19 am    Post subject: Reply with quote  Mark this post and the followings unread
Sure! try the comand-line options.
The default sample-rate on Linux is 48K but it can be changed using something like this;
chuck --srate44100 --loop funky_techno.ck
You can also set the buffersize that way, the log-level and so on.
http://chuck.cs.princeton.edu/doc/program/vm.html
(mysteriously that page doesn't cover the log-level but if you need that too I'll find the exact syntax for you)
In case you forget the exact spelling of those (I do that a lot) this will sort you;
chuck --help
Also this;
second/samp => float srate;
Will tell you the samplerate within ChucK which would be usefull if you want to trade files with people on other rates yet keep samples in tune (using a fraction and stting the playback rate according to that.)
Hope that helps.
everamzah
PostPosted: Thu Apr 12, 2007 11:18 am    Post subject: Reply with quote  Mark this post and the followings unread
*smacks forehead* you're the best kas! so patient and helpful for such a silly question. Wink thanks!
PostPosted: Thu Apr 12, 2007 12:17 pm    Post subject: Reply with quote  Mark this post and the followings unread
Not at all, we're here to help eachother. Asking question is good.
