janvanvolt
Joined: Nov 24, 2005 Posts: 285 Location: Mainz, Germany
Posted: Mon Jan 21, 2008 4:27 pm Post subject:
Okay, find my problem. i do not had a connection on the *Free resistor.
i put a trim 2K there and the delay is fine with around 1.5K resistor, but it's adjustable. i probably try to insert a pot for "quality" as in the one extreme setting, it's really lowfish (and noisy) but nice. _________________ Homepage - http://www.czmok.de
My dIY - http://diy.czmok.de
Film/Music - http://gfm.me |
creatorlars
Posted: Thu Mar 20, 2008 9:47 pm Post subject:
Just wanted to say, I finished building this from the PCB and it works great! Having a lot of Throbbing Gristle type fun with LFO delay and a microphone. >
The Feedback range seems very limited, though -- I'm only getting 4-5 repeats at maximum setting -- is this all I'm gonna get? The Rebote 2.5 I built seemed to get a lot more. |
ericcoleridge
Posted: Wed Aug 13, 2008 10:14 pm Post subject:
Would there be any possible way to clock a delay circuit like this from a pulse/trigger/gate signal?
So that one could sync the delay up to a rhythm track for instance?
I read through this thread looking for a hint of this kind of idea, but didn't find anything. |
creatorlars
Posted: Thu Aug 14, 2008 7:56 am Post subject:
| Not that I'm aware of -- but let me know if you find anything! I wonder if there would be a way to patch something like that up with a trigger/gate delay, an envelope, and something like a LPG...? |
Photon
Posted: Thu Aug 14, 2008 10:01 am Post subject:
| creatorlars wrote: | | Just wanted to say, I finished building this from the PCB and it works great! |
From the PCB? Where did you get that?
thanks
Peter |
creatorlars
Posted: Thu Aug 14, 2008 10:14 am Post subject:
| Quote: | | From the PCB? Where did you get that? |
It was self-etched from the PCB layout in this thread. |
Photon
Posted: Thu Aug 14, 2008 10:19 am Post subject:
thanks, I missed that!
Peter |
guitarfool
Posted: Tue Aug 26, 2008 6:15 pm Post subject:
| creatorlars wrote: | | The Feedback range seems very limited, though -- I'm only getting 4-5 repeats at maximum setting -- is this all I'm gonna get? The Rebote 2.5 I built seemed to get a lot more. |
I changed R7 from 100k to 24.9k - it now will echo indefinitely with the recirculation (feedback) pot at it's maximum setting. It will self oscillate too (although it sounds more like an outboard motor than anything else). You could probably use something even smaller than ~25k if it floats your boat  |
crashlander42
Joined: Oct 21, 2006 Posts: 292 Location: Orlando, FL (US)
Posted: Tue Sep 16, 2008 11:28 pm Post subject:
Just finished this thing! New favorite module!
Dumb question, which one is R7? I changed the resistor that I *thought* was R7 and it ceased working until I put the 100k back in.
I could probably figure it out if I gave the PCB and schematic a good stare.
Plugging the Wogglebug up to this thing is sure sanity drain. _________________ When they plug me in the lights go down in Hong Kong.
My DIY stuff Flickr |
guitarfool
asafnetzer
Posted: Thu Sep 18, 2008 12:14 am Post subject:
I was wondering, hoping really If one of the capable people here could etch me 2 boards.
I would pay for the parts, labor, shipping.
Thanks,
Asaf |
sduck
Posted: Thu Sep 18, 2008 8:14 pm Post subject:
| This sounds like a cool delay - I might be tempted to put one of these together. I've got a Blacet Time Machine, which I can never get a decent sound out of. I see futurelec has the pt2399 - so this shouldn't be a problem. I've been playing around with expresspcb, so may be able to help the previous poster out with a board or 2 if I figure it out. |
macumbista
Posted: Thu Oct 23, 2008 4:01 am Post subject:
Before I go making this... can anyone post some decent sound samples? As I wrote earlier in this thread, I've already built the Tonepad ReBote delay using this same IC, and was very disappointed with the high frequency response, especially on the repeats. The lowpass cutoff is too steep in that circuit. So I'd like to know if this circuit is better in that regards. If anyone has made both, I'd also be interested in a one-to-one comparison, or even just your opinion on the difference in sound.
EDIT: found the sound sample on page one of this thread... still seems like a lot of lowpass going on, could be a lot crisper sound. Could anyone who has both delays built comment on any differences? Thx! Derek |
etaoin
Joined: Jun 30, 2005 Posts: 761 Location: Utrecht, NL
Posted: Thu Oct 23, 2008 5:59 am Post subject:
| guitarfool wrote: | | I also added a jumper (shown in purple) that was not marked on the original parts layout (earlier part of this thread). |
Funny enough my version doesn't have that jumper, but works nonetheless. Looking at the schematic, it shouldn't, really. _________________ http://www.casia.org/modular/ |
Pehr
Joined: Aug 14, 2005 Posts: 1307 Location: Björkvik, Sweden
a.b.o.z.
Joined: Feb 07, 2007 Posts: 351 Location: Zagreb, Croatia
G2 patch files: 4
Posted: Mon Oct 27, 2008 3:51 am Post subject:
| I'll try it tonight and post result. |
yusynth
Posted: Mon Oct 27, 2008 3:59 am Post subject:
| Quote: | | How about removing the 0.01 µF and the 0.027µF caps? Those are filter caps, right? would that 'clean up' the sound? |
Mind you that's exactly the reverse effect because these low-pass filters are there to "clean up" the sound by removing aliasing effects due to sampling frequency. If you rise the cut-off frequency of these lowpass filter you certainly will gain in higher frequencies but also you will introduce aliasing (spectral folding) and it may sound worse as a matter fact... _________________ Yves |
macumbista
Posted: Mon Oct 27, 2008 4:02 am Post subject:
I think I tried this and got runaway feedback. Maybe some trimmer caps in there could work to fine tune it? I'll also pull apart one of the boards I made with this and check a few things out... _________________ Esoteric drones and nonlinear distortion
macumbista.net |
Joined: Jul 18, 2006 Posts: 50 Location: Marseille - France
Posted: Mon Oct 27, 2008 4:15 am Post subject:
You should take a look to the 2399 datasheet.
If I remember right, the 4 0.1uF caps attached to 2399's pins are involved into signal filtering.
Here is the schematic of the PCB published in this thread
http://sdiy.free.fr/CVdelay/ScottBernardi_VCdelay.pdf |
Pehr
loss1234
Posted: Thu Jan 15, 2009 11:40 am Post subject:
Hard to reply because longer is the delay, crunchier is the sound. About 5-7 seconds but very lofi perhaps even more, 1-2 seconds for a "hifi" setting if i recall correctly.
The longest delay is shortest than my boss PS2 pedal.
Edit : Sorry Loss, I misread your last sentence. |
casperelectronics
Posted: Wed Jan 21, 2009 1:30 am Post subject:
I finally got mine working but I'm not too satisfied with it's performance.
The decay setting is really problematic. As many people have mentioned, the filter is very aggressive.. I'm getting maybe 4 repetitions. I changed out R21 for a trim pot to allow for more decay, but even with more decays, they just filter into mush by 4-8 reps. I've built several Rebote delays and I install endless repeats on all of them. I've never had any problems with the repeats being SO degraded. HELP!
Is it important to use a OPA2134 for IC1? I'm using TL072s for all opamps. I've tried switching out for other dual ops with no recognizable difference. |
Posted: Wed Jan 21, 2009 3:23 am Post subject:
Hello Casper,
Do you think there's too much lowpass filtering to allow endless feedback ?
I don't really know which caps is involved in feedback filtering. I thought it was the 4 0.1uF caps, but I'm not sure. I'll had to disconnect these four caps to have an answer.. What's caps value are use in this place on the rebote delay ?
No need for 2134, I've just got some, and use them often on VCA circuits. They're cleanest than 072 on high frequency, but probably aren't so usefull here, as we have too much lowlass filtering.
edit : 2399 datasheet: http://www.synthdiy.com/show/?id=1806 |
Posted: Fri Jan 23, 2009 8:35 am Post subject:
My apologies about the 4 filtering 0.1F caps I mention twice in this thread. Those are not involved in filtering.
C3 5600 pF, C4 560 pF, C11 560 pf and C10 5600pf are the filtering caps tied to PT2399 Pin 13/14/15/16. I calculated the cutoff frequency of these 2 lowpass filters, and it seems to be about the same than Rebote 2.5. |
