ASM-2
Page 2 of 8 [192 Posts]
PostPosted: Thu Jul 27, 2006 3:06 pm    Post subject: Reply with quote  Mark this post and the followings unread
Thanks BigTex,
I know what you mean about having common mod type inputs next to each other. I was trying to break them up, thinking that, as they are just SPDT's, having different inputs paired together would decrease the similarity of function between the two. But I'm now wondering whether that is actually true. I've got a feeling that it's 6 to one, half a dozen to the other, if so, you're absolutely right. Unless I had the same inputs multipled to rotarys on every mod, there will always be some combinations which are inaccessable.
I'm gonna sit back and imagine actually setting up some sounds tonight.
bigtex
PostPosted: Thu Jul 27, 2006 3:08 pm    Post subject: Reply with quote  Mark this post and the followings unread
Yes. Like "air guitar" except with "air patch cables" (rocking out!).
Smile
PostPosted: Tue Aug 15, 2006 3:53 am    Post subject: Finalising the layout (help needed) Reply with quote  Mark this post and the followings unread
Okay dudes, (and Dudettes)
I need some serious help now.
The layout is almost finished, but I need some sharp eyes to look it over and give me some specific feedback about connection options, etc. I'm particularly unsure about the gate and trigger options on the ADSRs.
I've included some of your previous ideas; -
Like similar mod option groupings, and noise mod options for the VCFs and RingMod, and LFO as a S&H input. In fact I've doubled the number of modulation options by incorporating more rotary switches (I had a stock of them anyway).
And any problems with the aesthetics of the layout as well.
As you can imagine, once I start drilling holes and mounting components, Murphy's law says that some things will need to change. I just want the list of unplanned modifications as short as possible.
Thanks in advance to anyone who has the time to help. Very Happy
PS Thanks for pointing out that Sorcerer only has 1 "c" in it!! Doh!@ Rolling Eyes
 Filesize:  202.7 KB
 Viewed:  815 Time(s)
zipzap
PostPosted: Tue Aug 15, 2006 10:24 am    Post subject: Reply with quote  Mark this post and the followings unread
Just some thoughts: I would like some patching options and say 1 or 2 mixers with the option to rout them to your cvs. You´ve already covered most possibilities, but you never know. Those rotary switches might have a few more settings.
You´ve got octave and tune pots. If the tune-pot has to cover an whole octave it might not be finetunish enough.
For the lfos i would include a shape-controll. Never want to miss it!
And independant rise and fall lag can be very powerful and takes only another pot.
How are the vcfs and vcas connected? parallel/seriel?
The overall design looks really cool!
http://www.myspace.com/lorolocoacousticpop
music and transcribed jazz basslines
PostPosted: Tue Aug 15, 2006 4:14 pm    Post subject: Reply with quote  Mark this post and the followings unread
The section at the bottom will have normalised 6.5mm patch points, but I'm afraid I can't fit any more controls, (I've already got the sheet of aluminium, and at 430*530 I wouldn't want it any bigger.)
The octave switchers will have their own trimmers, referenced off the precision +/- 10V supply inside, so I don't think the fine tuning will be a problem.
What exactly do you mean by shape control, and rise fall lag? The PCB is finished, so I'm not really doing much more in the way of actual circuit function mods.
I'm going to have separate outputs for each VCA. They can be fed by mixed levels of either VCF, which in turn have a separate mix of the four sources.
zipzap
PostPosted: Wed Aug 16, 2006 8:17 am    Post subject: Reply with quote  Mark this post and the followings unread
Rise and fall, i mean that instead of one speed (or lag) pot, you have two, each with a diode. One controlls the charging, one the discharging of the cab. This can be musically very interesting.
PostPosted: Fri Aug 25, 2006 4:02 am    Post subject: Reply with quote  Mark this post and the followings unread
Here's the patchbay section at the moment.
I've got some extra spots to fill up, but I'm unsure of what I might want. Anyone got any suggestions?
This photoshop doc has now reached the 140MB mark! Surprised
And it's only in greyscale!! Shocked
Over 80 layers, in case I suddenly decide to change the fonts! Rolling Eyes
But it's almost finished! Then I'll be able to start putting it together! Yeah! Very Happy
 Filesize:  21.24 KB
 Viewed:  798 Time(s)
questionable
PostPosted: Tue Aug 29, 2006 12:39 pm    Post subject: Reply with quote  Mark this post and the followings unread
anyone have any audio file examples (i've already listened to sneakthief's "noodling")?
PostPosted: Wed Sep 06, 2006 7:17 pm    Post subject: Reply with quote  Mark this post and the followings unread
Here's the first three construction photos. Let me know if anyone finds these handy or inspirational.
First up, I attached a 20*12mm L stock frame all around the 2mm front panel. This helps to stop any flexing in the panel, and gives me something to attach the rest of the case to.
 Filesize:  103.73 KB
 Viewed:  576 Time(s)
I decided to pop rivet the frame on, as the front will be covered in veneer and I didn't want any chance of things coming loose etc.
I had to countersink the rivet heads so they wouldn't cause lumps behind the veneer.
 Filesize:  83.22 KB
 Viewed:  629 Time(s)
Then I filed the rivet heads flat with the surrounding panel. The great thing about covering this in veneer is it actually helps if you scratch it up.
 Filesize:  113.08 KB
 Viewed:  618 Time(s)
PostPosted: Thu Sep 14, 2006 3:52 am    Post subject: Reply with quote  Mark this post and the followings unread
Okay,
here's the next set of three pics.
Things are moving along really well.
I printed off some reversed drilling guides and centre punched every hole from the inside.
I wanted to drill the locator holes first, as they only go through the aluminium. I always put pilot holes of 1.5mm (1/32) through first and then use wood drill bits (they have the outside edges raised with a spike in the middle) for any hole which you want centred and round! You can buy them from hardware stores, but you can make your own out of a standard bit, if you have some kind of grinding wheel, and a bit of practice.
With all the locator holes drilled and cleaned, I wiped over with some isopropyl alchohol and ironed on the veneer sheets. After filling the grain and sanding smooth, I gave it a coat of satin enamel. Next morning I decided it was too thick and wiped it off with turpentine and an open weave cloth. It actually ended up being a really beautiful finish. Now to drill the real holes!
Here, my beautiful assistant shows how easy it is to swing a hammer!
 Filesize:  62.82 KB
 Viewed:  499 Time(s)
Locator holes drilled, time to iron on the veneer.
 Filesize:  92.87 KB
 Viewed:  561 Time(s)
Finished panel ready for real holes.
 Filesize:  104.36 KB
 Viewed:  587 Time(s)
PostPosted: Mon Sep 18, 2006 4:34 am    Post subject: Reply with quote  Mark this post and the followings unread
And here we have it with all holes (except the power switch) drilled.
 Filesize:  107.33 KB
 Viewed:  553 Time(s)
sneakthief
PostPosted: Mon Sep 18, 2006 7:40 am    Post subject: Reply with quote  Mark this post and the followings unread
that's impressive! does it qualify as furniture too? heheh
i forgot if you mentioned how you're going to label it - i'm quite curious.
i'm having visions of you using one of those "wood burning kit" engravers Wink
have you received the kit from elby yet?
michel
Sneak-Thief - raw electrofunk
Former site admin
Audio files: 353
PostPosted: Mon Sep 18, 2006 8:47 am    Post subject: Reply with quote  Mark this post and the followings unread
Those holes are in line !! wow ! wish I could do such ...
PostPosted: Mon Sep 18, 2006 8:55 am    Post subject: Reply with quote  Mark this post and the followings unread
Oh it's furniture all right!
This is gonna be a work of art!
Family heirloom kind a thing.
The labeling has already happened.
I did it with Lazertran yesterday.
It's looking Beautiful! Very Happy
Photo coming tomorrow.
I've had the PCB for a couple of years. Collected all the parts myself except for the hard to get bits. Laurie has a "special components kit" which I got a couple of months ago.
sneakthief
PostPosted: Mon Sep 18, 2006 9:00 am    Post subject: Reply with quote  Mark this post and the followings unread
pics with Lazertran pleeeease Smile
how much of the PCB have you assembled?
there are some weird things here and there, so be SURE to download the newest docs from the elby site when you start stuffing parts.
and please let me know how your VCO calibration goes; i want to hear about your experiences with this.
Scott Stites
Audio files: 97
PostPosted: Mon Sep 18, 2006 9:13 am    Post subject: Reply with quote  Mark this post and the followings unread
Wow, that's nearly large enough to accomodate the control section of the Model 2 Klee Very Happy
PostPosted: Mon Sep 18, 2006 2:18 pm    Post subject: Reply with quote  Mark this post and the followings unread
The PCB is virtually finished. My one is from the first ever run, and has a number of errors, (which I fixed) Laurie has since released a new version which is almost perfect. Even with the fixes, the PCB was definately easy compared to what comes next. Cool
questionable
PostPosted: Mon Sep 18, 2006 9:09 pm    Post subject: Reply with quote  Mark this post and the followings unread
Not to hijack your thread, but here's a slightly different take on the ASM front panel. Going fully modular on this one and borrowing heavily from Sneak-Thief's layout and expertise. My PCB is still on the way...
Mine seems so plain next to your wood-paneled goodness. Smile
 Filesize:  57.07 KB
 Viewed:  22735 Time(s)
PostPosted: Tue Sep 19, 2006 2:42 am    Post subject: Reply with quote  Mark this post and the followings unread
Well,
different strokes for different folks. Very Happy
It's the diversity of the human being which gives it so much added charm and value.
I think your classic black modular style looks very cool.
It will be interesting to see (hear) how similar (or not) they sound. Wink
PostPosted: Tue Sep 19, 2006 2:47 am    Post subject:   Reply with quote  Mark this post and the followings unread
Hey everybody!
Cop an eyeball full of this candy!
I is one happy chappy! Very Happy Very Happy Very Happy
 Filesize:  190.71 KB
 Viewed:  686 Time(s)
 Filesize:  122.74 KB
 Viewed:  603 Time(s)
questionable
PostPosted: Tue Sep 19, 2006 7:09 am    Post subject: Reply with quote  Mark this post and the followings unread
now that is cool.
Audio files: 266
PostPosted: Tue Sep 19, 2006 7:46 am    Post subject: Reply with quote  Mark this post and the followings unread
Very impressive Uncle K.
That beautiful assistant is truly beautiful. That's a great picture. Wink
PostPosted: Thu Sep 21, 2006 10:26 pm    Post subject: Reply with quote  Mark this post and the followings unread
As I don't plan on building another one of these anytime soon, I thought it would be extra helpful to others at this point if I go through a few things I would have done differently if I'd known what I know now. There are always mistakes and miscalculations to be learned from.
All the pots, rotary switches, toggle switches, LED bezels that I'm putting in this panel will fit,..... just. The octave switcher in the top left will clear the side panel of the case by about 1mm. The 6.5mm jacks on the bottom row will have one side sitting on the angle bracket in the edge. I'm going to put 1.5mm strip behind all of them, as this will set them back a bit anyway, which looks nice. A couple of other bits down the side are in a similar spot. So even though it ends up using some extra space, if you need a bit of room, add an extra 3-5mm around the edge of a project like this. I'd have done it as an extra thickness in the black border and re-spaced all the artwork to suit.
The wood veneer is really nice, I love the look of it. But,.... I don't think I'd do it again. At least not the same way. If you really want the woodgrained finish using a particular type or quality of wood, go ahead and use veneer (iron on if you can find it) but iron it on to a piece of 3mm marine grade ply. Then glue this (using contact glue (properly)) to a sheet of 1mm aluminium. Glue them after cutting all holes in each separately, (line them up by clamping and drilling 1.5mm pilot holes through each position first) If you don't want the veneer on the front just use the ply and lay your art work straight onto that. The reason is that even with scratching the aluminium up and properly cleaning it, drilling the main holes still resulted in the veneer lifting in a couple of spots. This won't matter when the components get put in, but as well as that, I've realised that I could sit the knobs right down to the wood if the nuts and washers on the rotaries and pots were sunken into the wood panel. It just means drilling clearance holes in the wood layers, and mounting them on the aluminium layer. Hope that makes sense.
sneakthief
PostPosted: Thu Sep 21, 2006 10:50 pm    Post subject: Reply with quote  Mark this post and the followings unread
hey unkle krunkulus *heh*!
i'm not surprised that you ran into weirdness with clearances and such. that said, a serious effort had to have been put in to get nice results like that.
i'm itching to hear about your wiring experiences - will you be starting that soon?
i may rip out my elby octave switchers and replace them with a coarse-tune pot (i only have a fine-tune pot on mine). i can't get them to work!!! i calibrated them with no load on them (1v,0v,-1v,-2v,-3v) - but when i connect them to either vco then don't switch proper octaves any more, even when connected to my blacet vco.
when i measure the voltages on the output when connected to the vco, they're all droopy, like -.9v, -1.8v, etc. hmmm.
michel
PostPosted: Fri Sep 22, 2006 12:13 am    Post subject: Reply with quote  Mark this post and the followings unread
How are the references you put into them derived? Did you use the +/-10V coming out of the LM329s or did you mod the octave switchers and use the +/-15V?
Under load or not, the only way it could droop is if the reference coming in is under. I'm assuming you built the switch PCBs fine 'cos you calibrated them alright.
BTW, yes, wiring will be happening ASAP, and probably for a long time! Laughing
