Coming up on Radio 1 at
bending Yamaha PSR-6
Page 2 of 4 [90 Posts]
wark_atoo
PostPosted: Sun Jun 18, 2006 8:33 am    Post subject: Reply with quote  Mark this post and the followings unread
Anyone do a pitch bend on one of these guys?
EraSer
PostPosted: Sat Jun 24, 2006 8:39 am    Post subject: Reply with quote  Mark this post and the followings unread
hi Very Happy
Finally I've a keyboard to circuit bend.My girlfriend give me the permission to circuit bend her Yamaha PSS-280. kiss
RAM chip is AN90B22 18 pins and CPU is XG214BO.I 've just found 14 good bend points....but I would know which pin of RAM chip I should keep away from bending.(I've found datasheet but it doesn't tell me the pins functions)
Do you think the best think to do is bending only points on the CPU?
I would'n t damage the keyboard. Wink
dnny
PostPosted: Sun Jun 25, 2006 9:01 am    Post subject: Reply with quote  Mark this post and the followings unread
Hi balance.
glad to hear that you got the permission to bend PSS-280
are you sure its a RAM chip? and can you point to the datasheet, because all i did find that AN90B22 is transistor array!?
are there any other chips than the XG214BO and the AN90B22?
there should be some FM and PCM action going on inside your Yamaha.
can you take a pic of both sides of the PCB? so that we could see the traces and the chips - also a map of the "good bend points" would help.
there is no safe way to bending, its a gamble. but try to stay away from power lines, even 9volts can make a mess.
see> DIY - destroy it yourself
take a look > guide for safer circuit-bending
www.koelse.org
flickr: cable porn group
EraSer
PostPosted: Mon Jun 26, 2006 2:19 am    Post subject: Reply with quote  Mark this post and the followings unread
Dnny
You are right. I'm not sure about AN90B22 Embarassed .I've found the same datasheet.
when I open it i can see also these three chips:YM7116, MC34072P, AN7148.....but they are far from the CPU. on the contrary AN90B22 is above CPU like in your pic.
as soon as possible.......
thanks dnny.these guides will help me. Wink
EraSer
PostPosted: Mon Jun 26, 2006 4:09 am    Post subject: Reply with quote  Mark this post and the followings unread
yES Very Happy
I've found FM chip:it's YM7116. I'm trying making connections betweent FM and CPU points .......and I can obtain strange and alien sounds! cyclops
I' will continue to try other connections....even if there's a problem:I would use a RCA patchbay but....There isn't space for it!There is the space only for switches near the first and last key.Can I use external rca module?Suggestions?examples?
balance
Track 1.mp3
Pss 280.......sounds very good!
 Filesize:  1.49 MB
 Duration: 1:38
 Viewed:  4551 Time(s)
PostPosted: Mon Jun 26, 2006 5:52 am    Post subject: Reply with quote  Mark this post and the followings unread
Hey Daniel,
Do you reckon this one's a goer?
I'm going to do a search on the chip at the front of the board. It's a lot bigger than the other ones, maybe it has 16 data lines? I'll let you know what I find out.
 Filesize:  99.75 KB
 Viewed:  2754 Time(s)
 Filesize:  108.96 KB
 Viewed:  2529 Time(s)
dnny
PostPosted: Mon Jun 26, 2006 11:37 am    Post subject: Reply with quote  Mark this post and the followings unread
balance wrote:
..Can I use external rca module?Suggestions?examples?
yes you can
try to fit a D25 connector somewhere and make a box whit RCA connectors something like this:
Posted Image
Posted Image
for more info visit highlyliquid.com
www.koelse.org
dnny
PostPosted: Mon Jun 26, 2006 1:48 pm    Post subject: Reply with quote  Mark this post and the followings unread
Uncle Krunkus wrote:
Hey Daniel,
Hi Andrew
i think you should give it a try. it has no FM but it's sample based.
Yamaha PSS-31 has the same CPU and ROM.
also the Yamaha PSR-150, PSS-21 and PSS-11 shares the insides of PSR-75
here is Yamaha PSR-75 owners manual
maybe there is some info there.
the ROM should be crystal clocked, but i don't see any crystal so maybe it's integrated Sad
www.koelse.org
PostPosted: Mon Jun 26, 2006 4:54 pm    Post subject: Reply with quote  Mark this post and the followings unread
That light blue blob is a crystal.
dnny
PostPosted: Tue Jun 27, 2006 12:59 am    Post subject: Reply with quote  Mark this post and the followings unread
CL1 right! I'm used to those metal cans cyclops
whats the frequency? maybe you could try over clocking and under clocking.
www.koelse.org
PostPosted: Tue Jun 27, 2006 7:36 am    Post subject: Reply with quote  Mark this post and the followings unread
"8.00T" is written on it, so I assume it's 8Mhz yeah?
I'm gonna do some testing of the interconnections between the chips to see what's going on. I can't find info on either of the chips, except that the XL437 is a 16bit ROM, and that the sounds (wavetable) are generated by the other chip. This could be good, could be bad.
I'm going to force myself back to finishing the SoundLab first though.
dnny
PostPosted: Thu Jul 06, 2006 12:42 am    Post subject: Reply with quote  Mark this post and the followings unread
today i got a Yamaha PSR-2
inside there is the following IC's:
LA4192 (1 to 2.3W 2-Channel af Power Amp)
C4570HA (dual op.amp. 9pin slim SIP)
and YM7137 CPU (40 pin) clocked whit 3.58 crystal
haven't find any info on the CPU - if some of you have something - even a pinnouts that would be great.
i will try to find some bend points and get you some pics soon - but I'm going off for a week so that might take a while. if someone is at dour festival (Belgium) come and say hi - i'm the guy doing lights when Aavikko is playing - or in Valkhofaffaire Festival (Nijmegen, Holland)
daniel
www.koelse.org
dnny
PostPosted: Thu Jul 06, 2006 1:21 am    Post subject: Reply with quote  Mark this post and the followings unread
hey balance. have you tried some easter eggs on your Yamaha?
I found this while surfing (The Easter Egg Archive)
On early Yamaha PSS keyboards, there is a secret mode that gives sound effects to the voice selection buttons. I know for sure it works on the PSS-80 'cos I had one about 10 years ago, and discovered it myself!
This egg will put sound effects and other wierd noises on your keyboard.
1. Turn off the keyboard.
2. Hold down the LAST two keys at the end of the keyboard.
3. Whilst continuing to hold the keys down,
turn the keyboard on.
4. Enjoy the new sounds!
there is one for Yamaha GX-76:
With the GX-76 turned off, press C2#, F2, G2# together. Then turn it on. Now move through the secret menu using the +(YES) and -(NO) buttons...
there must be others also Wink
www.koelse.org
EraSer
PostPosted: Thu Jul 06, 2006 11:49 pm    Post subject:   Reply with quote  Mark this post and the followings unread
WOW dnny! Shocked
really cool! Cool
I've tryed this secret mode on my PSS ....and it works!
thanks. Wink
-balance-
dnny
PostPosted: Fri Jul 07, 2006 12:28 am    Post subject: Reply with quote  Mark this post and the followings unread
nice!
how does it sound Question
www.koelse.org
EraSer
PostPosted: Sat Jul 22, 2006 4:38 pm    Post subject: Reply with quote  Mark this post and the followings unread
Hello
I've found a Yamaha PSS 780 I would buy:do someone know if it can be circuit bent? Or if you have it ,could you be so kind as to tell me what there is inside(CPU & FM)?.Thanks. Very Happy
dnny
PostPosted: Sun Jul 23, 2006 3:58 am    Post subject: Reply with quote  Mark this post and the followings unread
balance wrote:
Hello
well it's a FM synthesizer , so at least same kind of data line tweak could be done to it as the PSR-6. It has also MIDI! and drumpads Smile
so if you have the money why not - give it a try
some info can be found here :Yamaha PSS 780 at Waranty void
www.koelse.org
Basthian
PostPosted: Tue Jul 25, 2006 2:41 am    Post subject: Reply with quote  Mark this post and the followings unread
Any more news about the psr-75? How bendable is it? I have an opportunity to buy one but I'm not sure.
AbraC
PostPosted: Fri Aug 04, 2006 1:00 pm    Post subject: Reply with quote  Mark this post and the followings unread
i just started bending one of these. Im going to follow your build cause im new to this FM stuff. Im wondering if i can do this same kind of thing but with a yamaha fb-01 midi sound generator. Its multi timbral and has 8 yes 8 fm chips. I wonder if i could make a patchbay to mingle them all up. im trying to post a picture as an attachment, not sure if it will work.
 Filesize:  72.46 KB
 Viewed:  2219 Time(s)
AbraC
PostPosted: Fri Aug 04, 2006 1:14 pm    Post subject: Reply with quote  Mark this post and the followings unread
i actually lied about the fb-01, the synth chip is ym2164, i duno about bending it. any expertise would be greatly appreciated
dnny
PostPosted: Sat Aug 05, 2006 5:06 am    Post subject: Reply with quote  Mark this post and the followings unread
YM2151 is Yamaha's first single chip FM synth, was implemented not only to Yamaha's FM synth keyboards such as DX-21 (1985), DX-27, DX-100 but also to arcade games/home computers. In 1984 Atari acquired legal right to use it as their arcade components. (on the contrary, Yamaha didn't allow Atari to use it for home computers.) Their "Marble Madness" is known as the first video game using YM2151, then Sega, Namco and Konami followed.
YM2164 is almost identical to YM2151. Perhaps the only improvement is multi-timbre MIDI input support. YM2164 first appeared on the SFG-05 (an advanced version of the SFG-01 which added MIDI input) and later used for the FB-01 which was designed as a standalone MIDI module version of the SFG-05. It was also provided to Korg and they used it for the DS-8 (1987) and the 707 (1988).
i think the "cutting datalines"- kind of bend should work. just find the data lines and follow the instructions ... and let us know how it went
and welcome
www.koelse.org
zipzap
PostPosted: Wed Aug 16, 2006 12:32 pm    Post subject: Reply with quote  Mark this post and the followings unread
Hi. I just got a yamaha pss-190. Can i do something with it?
Dnny, it seems to have the same cpu that your psr-2
It´s a 40pin saying YM7137 3D and below XI257A0.
No idea what it´s doing. It´s the only chip on the whole board (exept for the audio amp).
Did you find any cool points with yours? On mine some pins seem to be unused.
http://www.myspace.com/lorolocoacousticpop
music and transcribed jazz basslines
zipzap
PostPosted: Mon Aug 21, 2006 2:42 am    Post subject: Reply with quote  Mark this post and the followings unread
How about clocking slower or faster? Anyone ever tried that?
Pehr
PostPosted: Sun Aug 27, 2006 10:21 am    Post subject: Reply with quote  Mark this post and the followings unread
dnny: What NPN transistor did you use for the LED-thingy?
btw, does anyone know where to find short RCA mono cables?
YouTube channel
flickr photostream
http://loxodrom.blogspot.com
PostPosted: Sun Aug 27, 2006 3:13 pm    Post subject: Reply with quote  Mark this post and the followings unread
Put some shielded cable and some RCA plugs in a box with a candle and some champagne. Close the box and put on some Barry White!! Laughing
