Oxygen 8 and more...
Page 1 of 1 [2 Posts]
miketbx
PostPosted: Tue May 23, 2006 5:56 am    Post subject:  Oxygen 8 and more...
Subject description: Need alot of help
Hi Guys,
I am kind of new to this music production. I primarily work in Adobe Audition 2.0. I also do some work in Sound Forge 8. Also, I plan to purchase Acid Pro 6 and Pro-Tools M-Powered 7. My problem is that I own an M-Audio Oxygen 8 midi-controller. But, I cannot get it to work- at all…
I am thinking about purchasing an M-Audio Axiom 25 to replace the Oxygen 8 because it looks like it is much more intuitive and is compatible with M-Audio’s Enigma software. That seems to be a good route for the midi-illiterate like myself.
I have a few questions:
1) Can I get the Oxygen 8 to work with Audition? If so how?
2) Will the Oxygen 8 work with Sound Forge? If so, how?
3) Will the Axiom 25 work any better with the programs I use or ones I plan to purchase? If so how?
Thank you for reading my long plea for help.
Frustrated,
Mike
Audio files: 25
PostPosted: Wed Jul 26, 2006 12:08 pm    Post subject: Reply with quote  Mark this post and the followings unread
I just came across this post and I may be too late. I own the same MIDI controller/KB and it works quite nicely with ACid Pro 6.0. The new ACid Pro 6.0 is wonderful so far and seems lots more stable than other versions. When you say it does not work at all, exactly what does not work? Does it work with other applications?
If you ever have doubts about if the computer is receiving MIDI data via the USB use a program called Midi-Ox. It's a great diagnostic tool that will allow you to see any MIDI data pouring into you machine. The controller should appear on the list of devices to open. If not, you have a driver/installation problem.
http://www.midiox.com/
Let me know !!
Bill
